SolaraGuy.com • View topic - noise after installing trd rear sway bar
Postby PEITRUS » Tue Nov 16, 2010 6:07 pm
I own a 2000 SE and after installing the trd sway bar, I get some banging sounds from the rear driver side strut area. I took out the seats and panels to check the struts, thinking they were loose. But they weren't. Sound only happens from going over smaller bumps on the road. Not so much over bigger ones...odd.
PEITRUS
Re: noise after installing trd rear sway bar
Postby ThatVietGuy » Tue Nov 16, 2010 6:12 pm
The bolts connected to your endlinks are loose.
ThatVietGuy
Postby kenny6683 » Wed Nov 17, 2010 7:55 am
or one of your rear strut mounts are done
kenny6683
Postby PEITRUS » Wed Nov 17, 2010 9:57 am
I'll check the end links again. And i am due for some new struts. Thanks guys
PEITRUS
