SolaraGuy.com • View topic - hooking up video to parking brake switch
Postby blackedout » Wed Mar 02, 2011 2:11 pm
So i just got a touch screen deck that is capable of playing video the other day. I hooked it all up and it works great, but there is a yellow/blue wire that needs to be connected to some wire of the parking brake. Any help on which wire and how to get to it would be great thanks!
2000 solara black, 18's custom paint, green HIDs, blacked out lights, 20% all around, 2 12" kenwoods
blackedout
Re: hooking up video to parking brake switch
Postby kingkakyle » Wed Mar 02, 2011 4:19 pm
basically its a ground wire
i just attached it to any bolt on the floor
Postby corlon » Wed Mar 02, 2011 10:31 pm
what brand and model number is it? if just grounding it all the time doesn't work you'll have to bypass it another way.
NiCe
corlon
Postby blackedout » Thu Mar 03, 2011 11:43 am
corlon wrote:what brand and model number is it? if just grounding it all the time doesn't work you'll have to bypass it another way.
it is a Dual XDVD700. It says on there to connect it to the parking brake switch because of the fact that it only works when the e-brake is up. So i dont believe i can just ground it but not completely sure
blackedout
Postby blackedout » Thu Mar 03, 2011 11:49 am
i have a Dual XDVD700. I think that i need to actually connect it to the parking brake switch because of the fact that the video only works when the parking brake is up.
blackedout
Postby 99BlackSandv6 » Fri Mar 04, 2011 5:10 pm
They tell you to connect it to the p-brake so that you can only use the video function
when the brake is engaged. It saves the company from liability.
You can ground it wherever you want.
Postby blackedout » Fri Mar 04, 2011 7:09 pm
Thanks!
blackedout
