SolaraGuy.com • View topic - Help Need new Clutch, not sure what one to get
Postby 01SolaraV6 » Fri Apr 01, 2011 3:18 pm
Clutch is slipping pretty bad, and i figure i might as well get a stage 2 or 3 clutch since i like shifting ah high rpm's
any suggestions out of the 3 brands
http://cgi.ebay.ca/F1-RACING-STAGE-2-PE ... 2507wt_905
http://cgi.ebay.ca/EXEDY-DAIKIN-OE-STAN ... 2533wt_905
http://cgi.ebay.ca/F1-HDSS-CLUTCH-KIT-w ... 2604wt_905
Thanks in advance
2001 Solara SE V6 (5speed) Silverstream Opal
Loaded
01SolaraV6
Re: Help Need new Clutch, not sure what one to get
Postby ThurzNite » Fri Apr 01, 2011 3:29 pm
The 2nd link, the daikin, isn't that just stock replacement with no added performance benefit?
Dr J
ThurzNite
Postby ThurzNite » Fri Apr 01, 2011 3:32 pm
That 1st one is ridiculously cheap if it's an upgrade. Is that a trusted brand, F1? I've had experience with ACT and Daikin in other cars, if u want my input on those.
Dr J
ThurzNite
Postby 01SolaraV6 » Fri Apr 01, 2011 3:51 pm
ThurzNite wrote:The 2nd link, the daikin, isn't that just stock replacement with no added performance benefit?
Dr J
Yea my bad, posted it quick, didn't see the OE
Loaded
01SolaraV6
Postby Twin Turbo » Wed Apr 13, 2011 8:49 pm
ATS Racing buds. I have the stage 6 and its the balls. You dont necassarily need the stage 6 but these MR2 clutches fit quite nice
http://www.atsracing.net/Parts.mvc/Index/CLUTCHFLY
Follow @ballsofthunder for non-stop ridiculous action
Twin Turbo
Postby ToyoSolV6 » Wed Apr 13, 2011 11:50 pm
I have an F1 clutch, and 2 other members do too, the are very agressive cluthes, if your stock i woulnt recomend you getting anything higher than oem, but if you want to get an aftermarket i would say stage 2 but with a kevlar disk, dont get a 6 puck too agressive for the stock car.
Postby KILLA CAM » Sat Apr 16, 2011 9:20 am
OP, where are you located??? We can swap clutches, I have a Spec Stage 2+!
_________________________
Retired: Honda S2000
Current: E46 ZHP
KILLA CAM
