SolaraGuy.com • View topic - Same tire ratings different tread?
Postby KingKevin » Mon May 16, 2011 2:48 pm
Ok so I bought new rims off of craigslist. They are 17" and came with some nice tires. The only problem is, I just noticed three of the tires are the same and one is different! They have the same rating (205/40/ZR17) and are all on the same rims and they have the same amount of tread wear. The only difference is the tread pattern. Is this ok?
2001 SE V6
Injen intake w/ extension - Renova Grill - custom catback exhaust - 2 12" Kenwood subs - Tein s tech - neons - 8000k headlights - 3000k fogs
KingKevin
Re: Same tire ratings different tread?
Postby DriDed » Mon May 16, 2011 3:12 pm
It is not recommended to have some tires with different tread patterns than the other.
+TRD front strut brace
+TRD rear sway bar
+Injen Short ram intake
+Pioneer DEH 2200 UB headunit
DriDed
Postby wkbrdr91 » Mon May 16, 2011 3:14 pm
I would personally worry about how it would handle in an emergency situation. Your supposed to replace tires either 2 or 4 at a time, not one. Put them on your car, go to a dry parking lot, do like 50 then slam on the brakes like a person just jumped in your path. Do the same thing on wet pavement. If your car turns/loses control you've got an issue. Much better to find out how your car acts in an empty parking lot than when some new driver or old lady pulls out in front of you as your going much faster than them.
2006 Solara Sport
wkbrdr91
Postby KingKevin » Mon May 16, 2011 3:24 pm
Thanks for re response. Definitely gonna try them out in a parking lot...
2001 SE V6
KingKevin
