SolaraGuy.com • View topic - Wood Frame painting over
Postby solaracjc2007 » Fri Jul 08, 2011 9:08 am
I have a 2001 solara, just bought it in March, and its practically brand new.
The only thing I have not liked so far is the wood trim in the car, not my personal choice considering the car is white and the interior is all black, the wood vinyl is throwing it all off. I bought some good vinyl paint and taped off sections so that I could paint it black, but its just not looking how I want, I'm gonna take some paint thinner and take it off. I am considering buying a trim kit....but I can't find one that matches my Generation on ebay. Any suggestions on where else I could try or what easier was I could paint them?
solaracjc2007
Re: Wood Frame painting over
Postby Pogs » Thu Jul 21, 2011 8:52 am
I do not know of any trim kits but I would suggest buying a cheap roll of stick on vinyl that you buy by the sheet. Then carefully lay it on and take your time.
Search and Win
Pogs
Postby ThatVietGuy » Thu Jul 21, 2011 8:03 pm
Code: Select all
http://www.solaraguy.com/search.php?keywords=trim+kit&terms=all&author=&fid[]=2&sc=1&sf=all&sk=t&sd=d&sr=topics&st=0&ch=300&t=0&submit=Search
Start digging.
And as always, SEARCH. It's there for a reason.
ThatVietGuy
Postby BuddhaSLE2000 » Wed Sep 21, 2011 11:28 pm
Have you thought about sanding it down and painting it a different color? I think if you sand down the trim so the paint gets in better and spray paint them it would be fine. if the car is white maybe white trim to change it up on the inside. I never really looked at the wood trim around the car. It has a lot of potential to add character so doing it black like the trim wouldnt show detail or a change in anything. thats just my opinion.
BuddhaSLE2000
Postby Solorange » Thu Dec 29, 2011 12:43 pm
I pulled mine out and gave it to the body shop to paint when I had them paint my TRD lip kit. I can't see it costing that much, but if you have a white car im sure you can find some white spray paint to closely match it. You will have to sand it down and spray some primer on it so the paint will adhere to it. This is what the body shop told me because they had trouble just painting over the glossy finish. Check out my cardomain page to see pictures or do a search on SG as I posted it a long time ago.
My Car Domain Page See second page.
Postby hari-bhari » Thu Dec 29, 2011 3:38 pm
get a sheet of carbon fiber vinyl and use that. looks good if you have the black interior
hari-bhari
Postby Mad_B_Rad » Wed Apr 18, 2012 7:25 pm
i simply removed all of the trim and painted it with black diplicolor trim paint, and clear coated it. put it back using a quack drying epoxy.
Mad_B_Rad
Postby epinkiert22 » Mon Apr 23, 2012 6:39 pm
I have black interior on my 99 and i got a roll of 3M carbon fiber vinyl and if you just take your time putting it on it comes out great
epinkiert22
