SolaraGuy.com • View topic - Rear Sway Bar (RSB) creaking, driving me nuts
Postby hari-bhari » Mon Dec 05, 2011 4:00 pm
My RSB (or so I presume) has been making a creaking sound over the past 4-5 months. Multiple attempts to have it lubricated have failed. Today I had my struts and springs replaced (Tokico/Eibach) due to wear, and also to ensure the creaking was not coming from there. Even after replacement of the suspension, the creaking still persists.
Do I need new bushings (not really sure which part is the bushing)?
Is there any chance it's the strut mounts?
Or is there a particular spot I can have the shop lubricate to get this to stop (pictures would help)?
It's driving me nuts!! Any help is appreciated!
hari-bhari
Re: Rear Sway Bar (RSB) creaking, driving me nuts
Postby hari-bhari » Mon Dec 05, 2011 11:33 pm
If the bushings need to be replaced, does anyone know which model?
hari-bhari
Postby kenny6683 » Tue Dec 06, 2011 7:50 am
I have same issue,. I believe it is bushings. Either way I am going to re-install stock sway bar and see if squeak goes away. It is very annoying.
I replaced springs and strut mount and it still makes sound. During cold days, it is worst
I will let u know once I swap it...maybe today
kenny6683
Postby kingkakyle » Thu Dec 08, 2011 3:59 am
interesting....i have the same problem, need to get some lube under there and ill get back
but oddly, mine squeaks less when its cold or rainy out haha
Postby Midias » Fri Dec 23, 2011 9:21 am
Get Teflon paste from home depot and lube the bar problem solved.
Postby GzNutz » Fri Dec 23, 2011 9:54 pm
Yeah, either paste or Teflon thread tape. I wrap the bar under the bushings and put synthetic grease over the tape.
Postby hari-bhari » Sun Dec 25, 2011 9:02 pm
so you dont think the bushing needs replacing? ive tried the mobil1 synthetic grease to no avail.
hari-bhari
Postby GzNutz » Sun Dec 25, 2011 9:21 pm
Unless you can see damage or deterioration of the bushing I would just try taping it.
Postby Midias » Sun Dec 25, 2011 9:37 pm
hari-bhari wrote:so you dont think the bushing needs replacing? ive tried the mobil1 synthetic grease to no avail.
I had no luck with that stuff. Teflon paste once a year and no squeaks.
Postby hari-bhari » Mon Dec 26, 2011 3:46 pm
so finally got the car jacked up today, took off the bushings, cleaned them and the RSB. one layer of teflon paste, then the mobil1 red grease, then teflon tape, and then more grease. put another layer on the inside of the bushing, and one more between the bushing and the bracket. took it for a short drive, no creaking. hopefully it lasts
BUT... HOW THE HELL DO YOU GET BOTH BRACKETS BACK ON?? I tried for about 3 hours, and I couldn't get the 2nd bolt (closest to the rear) of the left bracket to line up. I switched L <--> R brackets and still no luck. I had both sides of the car jacked up equally but also tried varying heights with no luck. So right now, one bracket is only bolted in partially and the sway bar is kinda hanging. Anyone have tips on how to get this damn thing back into place??
hari-bhari
Postby Pogs » Tue Jan 10, 2012 5:48 am
I had the same issue with not being able to get the bolt back in. Decided to take the bolt to local Ace Hardware and get a longer one with the same thread and was able to leverage the bolt where it was supposed to be.
Pogs
