SolaraGuy.com • View topic - loT LOT OF QUESTIONS...
Postby Jeaoma » Tue Jan 10, 2012 11:55 am
Okay some of these might sound stupid or w.e. But plz bare with me and if you have an idea or know the answer plz anything help: thanks in advance.
i have 00 solara, 03 front. 19" highlanders
-how low can i drop it on these wheels? Whats the best way to drop it?
_i was thinking of buying the tein springs from ebay_ they drop 1.4F & 1.7B
-how do i change the dome light, the one nxt to the rear view mirror?
_i cant quite find a spot to fit a flat head & pop it open_and what size bulb?
-"because of the 03 convertion i need to throw separate wires for the high & low beam"
but now my relay went? When i turn on the car even tho the switch is off the light are on.
- how do i fix that?
-new ratiator, car doesnt overheat but FAns dont go off... They do work
_maybe i havent waited long enough to see them run" idk wht to do.
-'Track off light blinks - ABS light is on also
_i press the button & nothing works it keeps on blinking.
-Finally: where can i get the TRD lip kit?
And how much do they go for new & used?
Jeaoma
Re: loT LOT OF QUESTIONS...
Postby Jeaoma » Tue Jan 10, 2012 11:57 am
And once again THANKS!
i just want to get this car on the road.
Jeaoma
Postby Jeaoma » Wed Jan 25, 2012 9:51 am
damn not 1 person can answer any of my questions....
i keep looking arround but cant find answers to exactly what my problem is...
Jeaoma
Postby ToyoSolV6 » Wed Jan 25, 2012 1:02 pm
Jeaoma wrote:Okay some of these might sound stupid or w.e. But plz bare with me and if you have an idea or know the answer plz anything help: thanks in advance.
for question 1, what the offset on your 19's? im sure the offset is high which makes the wheels go inside the fender and quarter panel. You can drop it on springs for a nice comfortable subtle drop i would recomend to roll your rear quarters. tire size also plays a big roll. If you get something thats too wide you will rub on bumps you have to figure out something that wont hit, a 225/45 19 im not sure if they make that size. Another form of suspension would be coilovers. This is a lot better considering the fact you can adjust height stiffness and camber. but be prepared to spend a pretty penny.
as for the TRD lip kit there are two memeber selling their kit for pretty damn cheap and its original TRD. look on the fs section.
Postby Jeaoma » Wed Jan 25, 2012 1:25 pm
Awsome thanks
Jeaoma
