SolaraGuy.com • View topic - 1MZ and 3MZ information
Postby Smaay » Fri May 25, 2012 5:06 pm
ok this thread shows the thickness of the 1MZ and 3MZ liners. Its intent is to see how much bore each engine can support.
lets start with teh 1MZ, here are the liner thickness and the thickness between the cylinders.
convert this to mm and you get 18.034mm
here are the 3MZ liners
here is my 2ZZ with darton sleeves installed in it, you can see the cylinders are way too close to go any bigger bore.
now i have no doubt that if someone was willing to start the adventure, Darton can make a sleeve and seriously bore out the 1MZ or simply bore out the 3MZ and you can get a 94 or 95mm bore, this with the 83mm stroke will give you
(.7854) X (9.4) X (9.4) X (8.3) X (6) = 3456.0176 which is a 3.4L engine and
(.7854) X (9.5) X (9.5) X (8.3) X (6) = 3529.9410 which is a sweet 3.5L engine
1990 Celica All-Trac 3S-GTE
1997 Celica GT 1MZ/3MZ hybrid
1997 Supra 2JZ-GTE
2001 Celica GT-S 2ZZ-GTE
1998 Dodge Ram Cummins Turbo Diesel
Thats alot of BOOST!!!!
Smaay
Re: 1MZ and 3MZ information
Postby SteveSolara » Fri May 25, 2012 7:56 pm
Thanks for the post, These information can come handy!
Image Image
SteveSolara
Postby projectSV » Fri May 25, 2012 10:22 pm
damn... i dont understand but im down to try anything! this tread isn't for 2gen 2azfe is it?
2004 2nd Gen SE Sport 2.4L 5 speed
"They say it's not worth the time, I say, It's time to show it's worth"
projectSV
Users browsing this forum: No registered users and 177 guests
