SolaraGuy.com • View topic - weapon r intake on a 99 v6 idiling really low
Postby wiseman » Thu Nov 22, 2012 10:38 am
Hey whats up hopfully im posting this in the right section but last night i hooked up my weapon r intake and it ran fine up untill the engine was warm now its idiling really low like under 1 i searched and the only other topic i found was someone having a problem with theirs idiling high so if someone knows what the problem might be help a new solaraguy out
Thank you
wiseman
Re: weapon r intake on a 99 v6 idiling really low
Postby 1gSE » Fri Nov 23, 2012 12:18 am
Been a while since I ran mine, but I believe once up to operating temp, it should idle around 700-800
Solara-M62 @ 5.5psi
1gSE
Postby wiseman » Fri Nov 23, 2012 11:22 am
Yeah mine is idiling at like 300 and bobbing up and down like right at the verge of shutting off
wiseman
Postby dinoxor » Fri Nov 23, 2012 12:01 pm
That sounds normal.
I idle at around 700 to 800 rpm as well with an injen intake
dinoxor
Postby 1gSE » Fri Nov 23, 2012 12:02 pm
Did you take anything else off besides what needed to come off for the new intake? Checked for vacuum leaks? Good seal around the MAF?
Solara-M62 @ 5.5psi
1gSE
Postby ToyoSolV6 » Fri Nov 23, 2012 12:13 pm
the intake wont be the problem. check for leaks, check if the air filter is on right
Postby GzNutz » Sat Nov 24, 2012 10:53 pm
Did you unhook the battery for a few minutes and let the car relearn its idle?
Postby wiseman » Sun Nov 25, 2012 10:30 am
I found the problem when we were hooking it up my friend plugged the small vacume hose because it was to small to fit on the intake i just kind of taped it together and its working fine now thanks for the help
wiseman
Postby Gregtrd » Wed Nov 28, 2012 5:28 pm
Now thats a wiseman!
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Postby wiseman » Thu Nov 29, 2012 9:25 am
Yeah stupid mistake it was the small hose that comes out of the top of the engine im getting the adapter for it but the tape is actually holding up for now
wiseman
