SolaraGuy.com • View topic - Cold Air intake?
Cold Air intake?
Cold Air intake?
Postby 00lara5127 » Mon May 13, 2013 1:46 pm
I am looking to get cold air intake. Whats the best look? I'm looking so spend around 150$ for something that will work well. I would rather not do any special modifications to make it fit and run right, just bolt it on. If anyone has one they are looking to sell I would be interested for sure, i dont mind used.
2000 SE 5-speed manual V6
00lara5127
Re: Cold Air intake?
Postby 1gSE » Mon May 13, 2013 1:53 pm
Injen with an extension
viewtopic.php?f=3&t=54276
Solara-M62 @ 5.5psi
1gSE
Postby ToyoSolV6 » Mon May 13, 2013 2:49 pm
Yup pretty much one of the few and very rare chances to pick up a full set like that.
Postby 00lara5127 » Tue May 14, 2013 4:44 am
i ordered a weapon-r dragon intake. Came to around $200. There were a couple guys with solaras or camrys that reviewed it and said it came out really well, so i went with it.
00lara5127
Postby 1gSE » Tue May 14, 2013 8:26 am
It's not a true CAI. Pick up an extension. You may need a different size coupler/reducer depending on what ddiameter the weapon r is. You'll see intake temperatures about 10-20 degrees cooler with the extension
Solara-M62 @ 5.5psi
1gSE
Postby Bdub215 » Mon Jul 22, 2013 3:56 pm
1gSE wrote:It's not a true CAI. Pick up an extension. You may need a different size coupler/reducer depending on what ddiameter the weapon r is. You'll see intake temperatures about 10-20 degrees cooler with the extension
Also make sure its not a full 3 Inch Extension. I ran into a issue on my avalon using a 3 inch setup and lost a ton of power under 5K but above it holy crap. i will note that my IAT's dropped by about 40-60 degrees on average. I need to make my extension about 2.5 inches and i should be fine.
Bdub215
Postby Gregtrd » Mon Jul 22, 2013 6:27 pm
If you tune your solara you can run any size.
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Postby Jaydo » Wed Oct 23, 2013 8:11 pm
Hi guys, can someone give me the rundown of why the extension length matters? I would assume (and from what I've read) that it has to do with the amount of ducting that is heating the air, but I'm not quite sure. The reason I'm asking is because I'm looking at the Injen but I want to understand the extension thing before I actually do it.
Any input is appreciated, thanks guys.
Jaydo
