SolaraGuy.com • View topic - AFM
AFM
AFM
Postby MR2 Biohazard » Thu Apr 03, 2014 7:12 am
I am running a 3mz with a 94 1mz harness, ecu and cable TB. I drilled the head and made a plate for the exh cam signal and just do not do anything with VVTi selonoids. It has been running good and fine, but I have a question on the AFM.
I am thinking the limiting factor to the intake is the very small 94 AFM.
I want to run this style if possible and put it in like a 3" tube.
This way it can really free up the air for the intake and should make more hp.
Thoughts on if it can work and the wiring to get it to work?
Thanks
Troy
MR2 Biohazard
Re: AFM
Postby Gregtrd » Sat Apr 05, 2014 11:03 pm
Run a TT supra maf, it's plug and play you will need to add 10% fuel across your entire tune.
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Re: AFM
Postby MR2 Biohazard » Mon Apr 07, 2014 9:31 pm
Thank you. I will try to find one and try that out.
MR2 Biohazard
Re: AFM
Postby Gregtrd » Tue Apr 08, 2014 8:15 pm
Not sure why you would drill the head for, you could of used one of the two 3mz cam sensors.
Gregtrd
Users browsing this forum: No registered users and 80 guests
