SolaraGuy.com • View topic - Debadge/shave
How to, DIY, and Get 'er done.
Debadge/shave
Debadge/shave
Postby Chinky420 » Fri Jul 20, 2007 4:02 pm
goo gone + fishing line...it worked for me.
1) apply goo gone above badges (so that it will seep downward/behind emblems). goo gone isn't hurtful to the paint (at least, not noticably...it may be molecularly damaging, but nothing that some wax wont fix)
2) let goo gone soak for 5-15 minutes
3) use fishing line to get behind the emblem, in order to pull the emblem off, as well as to 'cut' through stubborn adhesive on the backside
4) once emblem is off, use more goo gone + elbow grease (hands) to sort of 'roll' the remaining stubborn adhesive off (it should go without saying that you don't want to try and scratch it off...but i'm saying it anyway)
5) wash and wax
6) stand back and admire a job well done
you'll probably notice some uneven paint fading where the letters are supposed to be. there's not really any solution to this problem, rather, there are alleviations of it, i.e., park w/ that side facing the sun, wax and buff real thoroughly, clay bar....etc. personally, i debadged about 8 months ago, and can still notice some uneven paint fade (when i'm looking at the specific spots).
PLEASE TAKE NOTE: if doing tihs on a gen 1/1.5, you will be able to remove the trunk emblems without a blemish, HOWEVER, if you are in possesion of a gen 2/2.5, then be aware that there are two holes behind the emblem(s) (i'm not sure which one's), which are used to line up the placement. IF DEBADGING A GEN 2, PLEASE BE AWARE THAT THERE WILL BE HOLES BEHIND THE EMBLEM, which may be the difference between a DIY and having to take your whip to the body shop to have the holes filled.
hope that helps
Chinky420
Postby Down2TheC » Sat Jul 21, 2007 6:30 pm
Since you had an answer for the misposted request, I made it into a tutorial. If anyone else has a REAL method they like, please post it.
Down2TheC
Postby unbalancedwood » Sat Jul 21, 2007 8:43 pm
Forgot to add or its the wrong section...
Gen1 has NO holes
Gen2 HAS holes which need/should be filled
Maybe move to Gen1 tutorial...?
unbalancedwood
Postby Down2TheC » Sun Jul 22, 2007 5:20 am
This is Gen2 section. I'm sure Gen 1 has what they need whether in Tutorials or a/m mods.
Down2TheC
Postby PXLpainter » Sun Jul 22, 2007 2:48 pm
I used Bestine (rubber cement solvent) which you can get at any art supply store. The stuff will NOT harm paint or plastic. Heck, it will even remove a sticker off paper! :up: ;)
Postby Chinky420 » Sun Jul 22, 2007 3:50 pm
woah, yeah i have a gen 1 and didnt mention that the gen2's have the holes behind the emblems. i'll edit to include, but that really would be an important point (IMO), since that's the difference between a diy, and potentially having to take it to a body shop to fill the holes
Chinky420
Postby liltimmy1313 » Thu Oct 30, 2008 5:50 pm
I got an '04 garage kept Gen2...
if i take off V6 SLE, and the little TOYOTA symbol at the bottom, will there be fading?
its been garage kept its entire life, and has 75,000.
I dont really want fading...
2004 Toyota Solara V6 SLE, stock
but not for long :D
http://liltimmy1313.deviantart.com/art/ ... R-97881991
liltimmy1313
Postby ---CAMRAZY--- » Thu Oct 30, 2008 6:08 pm
Full debadged ass, FTW (as these kids say)
Postby no_escape » Thu Oct 30, 2008 6:48 pm
liltimmy1313 wrote:I got an '04 garage kept Gen2...
I have a DPW '99 with 167,XXX. I'm pretty sure Randy, the first owner, kept it in the garage and so have I. I dunno about the other owners inbetween. I debadged with floss and goo gone... No fading.
no_escape
Postby Solarafreek » Thu Oct 30, 2008 7:25 pm
^ you probably wouldn't notice it much on white anyway.
Solarafreek
Postby no_escape » Thu Oct 30, 2008 7:40 pm
Solarafreek wrote:^ you probably wouldn't notice it much on white anyway.
True.
Dunno his color yet. Just trying to help out if any.
no_escape
Postby Ruski » Fri Oct 31, 2008 6:18 am
Clay bar it , the fading will go away after a good wax
Postby liltimmy1313 » Wed Nov 26, 2008 11:06 pm
yea its cosmic blue,
and i wash once a week and wax twice a year.
so cosmic blue is pretty light, and the car is well kept so i m assuming itll be fine
thanks for the help everyone.
but not for long :D
liltimmy1313
Postby mattyboy243311 » Mon Jan 19, 2009 2:17 pm
on the gen 2 are their holes behind the toyota and v6 se sign or just the main toyota and solara?
Thanks
mattyboy243311
Postby crispone » Mon Jan 19, 2009 2:23 pm
mattyboy243311 wrote:on the gen 2 are their holes behind the toyota and v6 se sign or just the main toyota and solara?
Thanks
NO HOLES behind the SMALL TOYOTA lettering and SE (SLE) etc... and V6 in the lower right.
G/L!
^^^ I didn't mess with these... and had no issues. :wink:
Return to Tutorials
