Homemade oil catch can
Ok, So I was getting alot of "blow-by" into the intake. I can't afford a nice catch can at the moment, but found this solution. I used a air compressor filter and put it in the vacuum line going to the intake from the valve cover. It's very simple and seems to be working great. I had this filter lying around in the garage, but you can pick one up at the local hardwhare store about $20.
So far I've put about 250 miles on the set up, and here's the pictures.
99 SuperCharged Lara
14.7@93 on 1/4mile (average)
Fastest run so far - 14.65@93
4.5psi
4.5psi
usoff89 - Regular SolaraGuy Member
