SolaraGuy.com • View topic - replacing starter contacts (clicking)
How to, DIY, and Get 'er done.
Postby bassthrive » Fri Oct 08, 2010 12:45 pm
Insert key, turn to start, *CLICK*...
Are your battery and associated connections OK, but starting is still weak? It may be worn starter contacts (the internal ones, inside the starter solenoid). Apparently this is a very common problem with high mileage denso starters.
I would like to share this helpful link. I did not write it, but it inspired me. My 120,000 mile contacts looked exactly like the before picture. I did not purchase an entire repair kit. All I got was two new copper contacts for $5 from a local automotive electrical shop (could not find this at autozone/advance/carquest).
http://www.4x4wire.com/toyota/maintenance/starter/
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Re: replacing starter contacts (clicking)
Postby Vuluz » Fri Oct 14, 2011 9:09 pm
This has happened to me before. I thought it was the starter too but it was actually my battery. I took it to autozone and it barely had any juice. Bought a new battery, never had the problem since.
Vuluz
Postby Down2TheC » Sun Oct 16, 2011 6:32 am
I had that on my 4Runner! I eventually got a new starter. Doh!
Down2TheC
Postby 1BADGTS » Thu Nov 22, 2012 6:43 am
Starter conacts are a very common problem with a very easy fix. The only warning I have for people doing this at home is to make sure the new contacts you put in are the EXACT same and installed in the same order as they came out!! In my 10 years with Toyota I have seen about a dozen people how have done this repair themselves and burned up the high voltage part of thier engine wiring harness (among other things) !! You can get contact kits (2 kits required) from your local Toyota dealer for less than $20 and it comes with everything you need and you know it will be correct for your car or truck. Some vehicles you need to take the old ones out, bring into your local dealer and match them up. For some reason Toyota doesn't show starter contact part numbers for all vehicles, thats why you need to match them up. Then just make sure you install everything in the same order it came out, this is very important !! As long as you follow those few simply rules, you can save yourself a bunch of $$$ !
****THE FLEET****
2001 Toyota Highlander Limited V6 - "The Wifes"
1999 Toyota Solara SE V6 5 Speed - Family Pimp Ride
1993 Toyota Celica GT-Four R/C Clone - Weekend Fun
1987 Toyota Supra Turbo 5 Speed Sport Roof - Just Because !!
1BADGTS
Return to Tutorials
