SolaraGuy.com • View topic - Toyota Supercharger Camry,Avalon,Solara V6
Auto Flea Market.
Postby ryan123004 » Mon Jul 19, 2010 4:40 pm
Up for sale is a used Toyota TRD Supercharger. This kit fits on the 3.0-liter V6 automatic or Manual Transmission.This supercharger was removed from a working Toyota Solara with a running engine under normal use. The part received proper attention and care. The supercharger was removed so that I could perform routine maintenance (plugs, wires) that were not assessable with the part in the way.
This kit will work with the following vehicles
-1997-2000 Camry 3.0-liter V6
-1997-1999 Avalon 3.0-liter V6
-1999-2000 Solara 3.0-liter V6
Items that are NOT included, but you WILL need
-TRD EGR pipe (either manual or automatic transmission - they are different parts) can be ordered from TRD directly
-Various bolts (can be found at any car parts store, they are standard metric sizes)
-Various hoses (I have included most of my used hoses, but I would recommend new hoses (very very cheap, again at an auto parts store)
TRD Supercharger for 3.0 liter V6
adds 50 hp
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 427wt_1165
ryan123004
Re: Toyota Supercharger Camry,Avalon,Solara V6
Postby Dawgz » Mon Jul 19, 2010 5:29 pm
ryan123004 wrote:Up for sale is a used Toyota TRD Supercharger. This kit fits on the 3.0-liter V6 automatic or Manual Transmission.This supercharger was removed from a working Toyota Solara with a running engine under normal use. The part received proper attention and care. The supercharger was removed so that I could perform routine maintenance (plugs, wires) that were not assessable with the part in the way.
adds 50 hp
The egr can not be ordered any more. And some bolts can be found at the hardware store, but they won't be the same thread pitch. If u need specific bolts, then pm me.
Postby argon18 » Sat Jul 31, 2010 1:15 am
I did not recieve a EGR pipe when I bought my kit of Gabe.
When installing, from memory I cut the existing EGR tube and used a length of 7/8" high-pressure, high-heat tubing to connect the EGR tube together. It seems to work fine.
Don't let the absence of the EGR tube stop you from buying one of these kick arse kits.
argon18
Postby 99BlackSandv6 » Sat Jul 31, 2010 1:20 am
^You used a silicone hose? That's clever and thrifty. :sweet:
Postby argon18 » Sat Jul 31, 2010 1:27 am
99BlackSandv6 wrote:^You used a silicone hose? That's clever and thrifty. :sweet:
Not quite silicone hose; although it would have been easier to use. From memory the tubing I got was reinforced so it was very very stiff. :-?
Yes! Silicone hose should do the job.
Edit: Now that I think on it, I have a piece underneath that engine cover I bought from you; I'll pull it out and see what kind of tubing it is.
argon18
Postby 99BlackSandv6 » Sat Jul 31, 2010 1:40 am
Ok, not silicone. I guess that might be a more universal
option though. Maybe it's easier to find silicone in .875id though.
I can't believe no one else thought of that before.
Instead people are paying BIG MONEY for original TRD tubes,
because they're rare. Just a GREAT idea! again--> :sweet:
Postby trd4life » Fri Aug 13, 2010 10:01 am
I have a like new TRD EGR tube for manual trans in stock $200 shipped.
Return to Wanted/For Sale
