SolaraGuy.com • View topic - Pic Request: Eric's Caliper Relocation Kit on Your Solara!
Postby ICrazyChrisI » Tue Sep 14, 2004 8:10 pm
I was wondering if those members with Eric's relocation kit could post their pics. Preferably from a close up angle like this Image (borrowed Erics picture) Also if you would, what size rim you're running on. Thank you!
ICrazyChrisI
Postby geminimouse » Wed Sep 15, 2004 10:20 am
i'm on 17's...16's won't fit
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby UfoZ8myCow » Wed Sep 15, 2004 5:09 pm
Not Eric's kit but its the same thing... Caliper relocation bracket, upgrade to V6 calipers, 13.1" rotors:
UfoZ8myCow
Postby TadS » Thu Sep 16, 2004 9:16 pm
I was going to wait to post picture's of all my projects at once, but since you asked here is a teaser :). 17's by the way.
TadS
Postby TRD_solaRa » Fri Sep 17, 2004 12:47 pm
UfoZ8myCow wrote:Not Eric's kit but its the same thing... Caliper relocation bracket, upgrade to V6 calipers, 13.1" rotors:
me likey dis one :drinking: . . . *sigh* one day . . .
TRD_solaRa
Postby cam2Xrunner » Mon Sep 20, 2004 1:27 am
^ I ve been meaning to paint the ugly part of the rotor.
cam2Xrunner
Anyone?
Postby mmcdonald » Wed Sep 22, 2004 8:52 am
Doesn't anyone know how to install slotted rotors? (top of the slot meets the calipers first, not bottom of the slot)
Are your install instructions telling you to do it this way?
2004 Solara SE Sport V6 Black
DocJohn's Vacuum Trick
K&N AF, Removed Secondary AF
XM Tuner DIY
mmcdonald
Postby TadS » Wed Sep 22, 2004 9:25 am
The Solara's rotors are labeled left and right, as are the calipers.
TadS
Re: Anyone?
Postby indiglosolara » Wed Sep 22, 2004 10:28 am
-MiltDoggie- wrote:
mmcdonald wrote:Doesn't anyone know how to install slotted rotors? (top of the slot meets the calipers first, not bottom of the slot)
This is another post I believe you have asked that, out of curiosity, is there somewhere that says what you are stating??? I don't have slotted rotors, but would like to know why you say all these guys rotors are installed wrong?? Thanks...
I dunno by my are installed top slot hitting the calipar first. I was told it was installed wrong but im not sure... if its suppose to be that way then i dont need to fix it. I was going to change it bac were the botton hits first.
Any confirmation of this would be cool...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby TadS » Wed Sep 22, 2004 11:33 am
I am on my 3rd set of rotors. I have had one slotted set from EBC. They entered at the bottom first. The rotors were clearly labeled L & R, as are the calipers, so unless EBC did it wrong, the slotted rotors I had were designed to hit the pads at the bottom first..
TadS
Postby Mole » Wed Sep 22, 2004 1:26 pm
rotor location can be either way DEPENDING on the company.
power slot has it so it slants /
where brembo for euro has it \
(this is how the slant goes when you are staring at the rotor)
Postby UfoZ8myCow » Wed Sep 22, 2004 1:43 pm
so it all depends on the brand then...
im with tads... mine were clearly labeled left and right, so im positive they are installed as they were meant to be.
UfoZ8myCow
Re: Anyone?
Postby cam2Xrunner » Wed Sep 22, 2004 11:59 pm
To tell you the truth I don't think it makes much of a difference. And if you think about it wouldn't you would want the slants to push the heat outward away from the center of the rotor not to the middle. I'd actually prefer not to have any slots or cross-drilling done. I would however like to fabricate some type of brake cooling duct similar to what the c5 corvette uses. And use something like this
with thisImage
http://www.westcoastcorvette.com/shop_online/prod_detail.cfm?id=1262&ref=froogle
cam2Xrunner
