SolaraGuy.com • View topic - Do you think it looks horrid in this location?
Postby Nutty101 » Thu Oct 14, 2004 10:56 pm
Nutty101
Postby Mole » Thu Oct 14, 2004 11:05 pm
looks like some one threw a chicken pot pie pan and landed upside down.
is that for XM? Sirius?
im starting to wonder why they have to be put outside of the car. why cant it go in the trunk or anything like that??
Postby Nutty101 » Thu Oct 14, 2004 11:13 pm
Mole wrote:looks like some one threw a chicken pot pie pan and landed upside down.
haha! I wish it was for that. It's a GPS/CDMA Reciever for a highend unit I have in my car.
Nutty101
Postby Mole » Thu Oct 14, 2004 11:22 pm
are there any other alternative antennas?
it just doesnt do any justice to put something like that one.
maybe on the roof of the car. MAYBE
Postby Nutty101 » Thu Oct 14, 2004 11:41 pm
Mole wrote:are there any other alternative antennas?
ROFL! Paint it red/blue. hahahahaha, would make people wonder thats for sure. Some people allready wonder when then see a camera looking at them. I really couldn't imagine it anywhere else. There are other antennas but this one is one of the only comercial grade antenna's that will hook into my system.
Desc:
this 3.3-5 volt hard mount antenna operates in GPS, cellular and PCS modes (the next gen MP series uses a 3.3 volt GPS module from Trimble)
1 1/8 inches high and 4 3/8 inches in diameter
offers rugged durability and low profile design
Specifications:
    Dimensions 3" (top) x 4.25" (base) x 1.125" (height)
    15 feet of coax with SMA male connector for GPS and TNC male connector for cellular/ pcs
Electrical Specifications
    VSWR at resonant point 1.5:1 or less
    Nominal Impedance 50 Ohms
    Gain 3 dB
    Polarization Vertical
    Maximum Power Input 125 watts
    Voltage 3 to 5 volts
GPS Performance (Antenna element & LNA)
    Center Frequency 1575.42 MHz
    Gain 30 dBmin.
    Polarization R.H.C.P.(Right Hand Circular Polarization)
    Noise Figure 2.0 max
    Arial Ratio 3dB max.
    Bandwidth 2 MHz min. VSWR 2.0 max
    Output Impedance 50 Ohms
Nutty101
Postby pythonjosh » Thu Oct 14, 2004 11:44 pm
Does it have to be level? I'd say take off the rear Toyota badge, put the antenna there, then put the Toyota badge on it. Sound good?
pythonjosh
Postby Nutty101 » Thu Oct 14, 2004 11:47 pm
pythonjosh wrote:Does it have to be level? I'd say take off the rear Toyota badge, put the antenna there, then put the Toyota badge on it. Sound good?
Yeah has to be looking up at the sky.
Nutty101
Postby cam2Xrunner » Fri Oct 15, 2004 12:24 am
Do you think it will have a problem getting reception through the glass? If not then you can mount in on the rear deck, between the speakers.
cam2Xrunner
Postby Nutty101 » Fri Oct 15, 2004 1:12 am
trdcamry2003 wrote:Do you think it will have a problem getting reception through the glass? If not then you can mount in on the rear deck, between the speakers.
Metal in the tint causes issues. :(
Nutty101
Postby Hsakuragi » Fri Oct 15, 2004 1:20 am
ADULT WARNING!
Get another receiver, custom paint the trunk like this below:
( o Y o )
will this look better? :drinking: :drinking: :drinking:
Hsakuragi
Postby krawzyazn » Fri Oct 15, 2004 1:23 am
put lil led lights on it and call it a ufo at night :drinking:
Postby Nutty101 » Fri Oct 15, 2004 1:42 am
hsakuragi wrote:ADULT WARNING!
( o Y o )
Now that is creative!! Some part of my mind just went. OHHHHHHH
Nutty101
Postby krawzyazn » Fri Oct 15, 2004 1:45 am
ooh pr0wlerartist has his there too but his is not round
ahhhhhhhhhhh....
Postby michaels artic frost » Fri Oct 15, 2004 4:48 am
I'm sorry to say this, but I hope that GPS/CDMA of yours is worth it, because that thing would annoy the crap out of me.
It looks like your best bet is to put it on the roof like Mike said. Since I'm seeing more and more antennas on the roof area, right before the back windshield.
Those GPS/CDMA aren't very cheap either. What model do you have?
Good luck... :drinking:
-Michael 8)
Updated 06/01/12: Michael T's
