SolaraGuy.com • View topic - My 5300K McCulloch's...
Postby cklinh » Wed Feb 23, 2005 5:40 pm
http://www.cardomain.com/id/cklinh
Page 4... also here...
I like them a lot... installation sucked cuz the little plug (that goes into the stock harness) didn't fit! I just ended up plugging the little spades directly into the stock harness and taped it up. There weren't any directions! Can anyone tell me what happens if I reverse the spades (black and white)? Would it cause electrical problems (and still work) or would it not work at all? Oh yeah, and that I think I blew a fuse on the factory amp that I can't seem to find (see other post in Gen 2)...
As you may be able to tell, a lot of the light above the "cutoff line" is due to the fogs (Nokya Arctic White Stage II)....
3/4 View
Front View
Front Cutoff
Side Cutoff
cklinh
Postby BradOwens » Wed Feb 23, 2005 7:29 pm
wow nice man. those things r bright ur gonna blind pplz comin at u :o haha
BradOwens
Postby krawzyazn » Wed Feb 23, 2005 9:22 pm
No problems if you reverse the wires the connectors need to be modified to fit H11 he said there not going to make the H11 connectors cuz theres not that much intrest in h11 like the 9006 :-?
damn it he didn't put the instructions in agian I need to talk to him about that
Postby cklinh » Thu Feb 24, 2005 9:20 pm
krawzyazn,
are there directions for modifying the connector to fit H11? I figure having a modified connector is better than my ghetto electrical tape.
I think it's not just the connector not fitting... the holes for the prongs are a lot further apart than they are on the stock bulbs...
cklinh
Postby cklinh » Wed Mar 30, 2005 12:32 pm
BUMP
Anyone know where I can get the H11 connectors so that I won't have electrical tape anymore?
Or how to do the modification that krawzyazn was talking about?
cklinh
Nice
Postby JayDubz » Fri Apr 01, 2005 8:24 pm
Very nice HID kit is that stock head light housing or did you get your head lights retro fitted with new projectors? and is your fogs hid's or just blue bulbs? they look nice..
2000 Galant... Mods in progress!!Image
http://www.cardomain.com/memberpage/350820/
JayDubz
Postby cklinh » Fri Jun 03, 2005 1:05 pm
krawzyazn wrote:No problems if you reverse the wires the connectors need to be modified to fit H11 he said there not going to make the H11 connectors cuz theres not that much intrest in h11 like the 9006 :-?
BUMP AGAIN...
anyone know of a source of the H11 plug/adapters? or how to do the modification?
cklinh
Postby JayDubz » Tue Jun 07, 2005 11:53 am
Yeah i know the headlights have stock projectors.. but the projectors that are stock are for halogen bulbs.. not hid's.. hence more glare for other drivers on the road.. retro fitting them would enable a better light on road and cleaner cut off line and alot more oem look.. thats all
but try http://www.hiddepot.com they might have a harness that converts it.. if not try emailing them im pretty sure they can make one..
JayDubz
