SolaraGuy.com • View topic - Gap
Gap
Gap
Postby RichD978 » Mon Apr 25, 2005 6:50 pm
is it me or are the gaps in the front and back different? If I drop it wouldn't it rub?
RichD978
Postby SolDoubt » Mon Apr 25, 2005 6:57 pm
Ya it does look off there. But the drop lowers the front a bit more so they should even out.
SolDoubt
Postby HKSV6SLE » Tue Apr 26, 2005 1:23 am
who cares? when i still had mine the back fo my car was noticeably lower. :drinking:
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby Jai_Jai_Binks » Tue Apr 26, 2005 8:18 am
after the drop the gaps is more evened out...but your 15's may make it seem bigger in the pic.
Edit: currently i'm on the same 15's setup and dropped, i don't rub, you WILL NEVER rub with stocks, unless you lower it wrong!
Last edited by Jai_Jai_Binks on Tue Apr 26, 2005 12:51 pm, edited 1 time in total.
Re: Gap
Postby Whatever » Tue Apr 26, 2005 12:46 pm
RichD978 wrote:[img]is it me or are the gaps in the front and back different? If I drop it wouldn't it rub?
lol wanna see the gap difference on my car???
you won't rub on stock rims and tires
Whatever
Postby 1st Gen Sol » Tue Apr 26, 2005 9:47 pm
You won't rub, but you might bottom out on those nice lob-sided pot holes and the sheets of metal layed down to cover the semi-repaired areas..........daym Massachusetts city streets...........
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby thealkimo » Wed Apr 27, 2005 2:02 am
--1LOKEDOUTSLE-- wrote:Are you guys for fucccken real???? The back fender on any car is cut lower, meaning the front is cut higher for turning purposes, hence the drop (even though it is even in the front and back) will look lower in the back than the front....
exactly!!!
always higher up front also to absorb the initial impact of speed bumps, potholes, etc better...
thealkimo
Postby CASTRO » Wed Apr 27, 2005 7:02 am
true but for performance, a lower front end (which makes the car looks flush) will give better steering response and help to reduce some understeer by tucking the nose in first. I know with mine, thats how it feels. Comfort wise, stick to having what looks to be a larger gap up front, the car is more even that way.
CASTRO
