SolaraGuy.com • View topic - New ATC
New ATC
New ATC
Postby SleeperSolara » Wed Jun 22, 2005 7:19 am
Finally got around to get this thing.
Sorry that these pictures are kind-of blurry.
The DIY plumbin' thanks to ACE hardware store.
Pass the radiator: Image
Top view: Image
Postby Paladin06Greg » Wed Jun 22, 2005 7:22 am
Are your hoses routed direct from tranny to cooler, meaning the car radiator is out of the loop?
Looks good.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby SleeperSolara » Wed Jun 22, 2005 10:30 am
Paladin06Greg wrote:Are your hoses routed direct from tranny to cooler, meaning the car radiator is out of the loop?
Looks good.
Nope still usin' the OEM factory cooler too.
Makin' that fluid nice and cooler.
Postby Paladin06Greg » Wed Jun 22, 2005 11:00 am
Humm you might want to reconsider that. I had mine that way at first but I later made the change.
Looks good.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby shidosha01 » Wed Jun 22, 2005 11:13 am
Good work!
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
Postby indiglosolara » Wed Jun 22, 2005 11:22 am
Paladin06Greg wrote:Humm you might want to reconsider that. I had mine that way at first but I later made the change.
Looks good.
why is that??
Can you explain the pro and cons of installing it that way??
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Paladin06Greg » Wed Jun 22, 2005 11:43 am
There are two schools of thought. One can be found here, I won't make you search. 8) (Where's Milt??)
http://www.solaraguy.org/viewtopic.php? ... er+install
The other focuses along the same lines except the intent is remove as much heat as possible from the engines cooling system a well. This line of thought leans toward a direct tranny to tanny cooler routing and that's what AMS recommeded and have chosen.
Anyone else want to speak on this?
Looks good.
why is that??
Paladin06Greg
Torqued Solara
Torqued Solara
Postby SleeperSolara » Wed Jun 22, 2005 2:19 pm
I just installed it to keep from cuttin' off teh radiator one cause lazy.
Though it would help to have extra external one.
Thanks for the comments
Postby indiglosolara » Wed Jun 22, 2005 2:58 pm
Paladin06Greg wrote:There are two schools of thought. One can be found here, I won't make you search. 8) (Where's Milt??)
Looks good.
why is that??
So should i bypass the stock one...?? that thread didn't really answer my question as to weather what the pro/cons of having it installer a certain way...
I was told to install it:
1. Tranny Outhose into stock ATC cooler
2. Stock ATC cooler to External (aftermarket) inlet ATC cooler
3. External ATC outlet back to return line of Tranny (inlet)
is this the correct way to do it... ???
your response is greatly appreciated
kenny
indiglosolara
Solara 2 xB
Solara 2 xB
Postby jazzlara » Wed Jun 22, 2005 3:34 pm
i installed them in series also. You wont get enough cooling power for the Trans with just the tranny cooler. they are designed to be extra protection. atleast thats what i was told.
of course, it depends on the cooler you got, how big?
jazzlara
Postby jazzlara » Wed Jun 22, 2005 3:35 pm
whats that T connector, for a temp guage?? if so, it looks like its installed in the hot line right?
jazzlara
Postby SleeperSolara » Thu Jun 23, 2005 10:00 am
jazzlara wrote:whats that T connector, for a temp guage?? if so, it looks like its installed in the hot line right?
I'm not sure, if i installed on the right on.
Thought the right one was the cold side.
But if i installed it wrong, oh well at least it workin' i hope.
I've already asked people which one it was people say the cold is the right one.
SOme say the left is the cold side.
So i went wit the right tube.
Postby indiglosolara » Thu Jun 23, 2005 11:07 am
I have the manuals.. so ill look into it today... but i have a B&M cooler also...
its about 11x7" in size.
i have it hooked in series also from the left side going out first... but i have to check on it...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby SleeperSolara » Thu Jun 23, 2005 12:55 pm
indiglosolara wrote:I have the manuals.. so ill look into it today... but i have a B&M cooler also...
Yeah PM which one it is.
I have the repair manual, but it don't say which one it is.
Postby so-cal_sol » Thu Jun 23, 2005 12:55 pm
good job... looks good.
2005 lunar mist metallic se V6
Trenz Grill
Eclipse 2454 HU
TRD springs *DROPT BY MILT*
so-cal_sol
