SolaraGuy.com • View topic - Quick and easy grille refurb...
Postby OKANG » Wed Sep 07, 2005 5:44 pm
Last weekend I refurbed my grille. It had the infamous chipping chrome problem.
Before
After
The entire grille was sanded and painted flat black. The center bar is covered with color-match vinyl and I might do the outer portion later on.
Cogito Ergo Zoom
OKANG
Postby BradOwens » Wed Sep 07, 2005 5:45 pm
nice. back in the day i painted my whole grille flat black with a silver emblem. 2 bad a guy i knew ruined it
BradOwens
Postby Sentinel » Wed Sep 07, 2005 6:14 pm
Did you sand it by hand or did you have a grit blaster?
Looks like a pain in da' ..
2000 SLEv6: TRD RSB, Eibach, Tokico
Sentinel
Postby ClassySolaraGuy » Wed Sep 07, 2005 6:37 pm
Nice work! Great pics too. How long did it take you?
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby OKANG » Wed Sep 07, 2005 8:37 pm
Sentinel wrote:Did you sand it by hand or did you have a grit blaster?
Hand sanded with 400, then 800. I just went over the tops of the small, vertical slats, so it wasn't too bad.
ClassySolaraGuy wrote:Nice work! Great pics too. How long did it take you?
It took me about 2-3 hours total, which includes drying time for the paint before applying the vinyl. The paint is Duplicolor Truck & Van, btw (the only aerosol paint I will use). It goes on thick, applies evenly, and dries very quickly compared to cheaper paints. The vinyl is from Avery and cost me $10. However, that's for a yard - enough to do the entire grille.
Cogito Ergo Zoom
OKANG
Postby Astro » Wed Sep 07, 2005 10:41 pm
Look nice. You should just vinyl the outer portion IMO, would look much better.
Postby Solorange » Thu Sep 08, 2005 12:34 pm
Im thinking about doing the same thing but just leave the silver chrome around the toyota emblem. I was goint to try a power washer to take the chrome off. If i set it to a single stream it and take the paint off a car so i figure it could take the chrome off.
Postby toy4x4boy » Thu Sep 08, 2005 3:30 pm
Is the vinyl factory white or is it just "white"?
toy4x4boy
Postby OKANG » Thu Sep 08, 2005 4:34 pm
Astro wrote:Look nice. You should just vinyl the outer portion IMO, would look much better.
Yeah, I may try that too. That's the beauty of vinyl - I can just pull the center bars off.
Solorange wrote:Im thinking about doing the same thing but just leave the silver chrome around the toyota emblem. I was goint to try a power washer to take the chrome off. If i set it to a single stream it and take the paint off a car so i figure it could take the chrome off.
I'm not so sure that would work. Even with sandpaper, it wasn't easy to remove.
toy4x4boy wrote:Is the vinyl factory white or is it just "white"?
It's a pearl white that's VERY close to the factory paint. I can't imagine getting any closer. Paint will look slightly different because it has more depth than vinyl.
Cogito Ergo Zoom
OKANG
Postby nj99solara » Thu Sep 08, 2005 8:39 pm
With the right power washer it will just blow off like dust....that's what I used to get what was left of my chrome off and it only took me like 30 seconds for the entire grille.
-4500k HID Bi-xenon kit
-4500k HID Fogs
-5% Tint in rear
-Tinted Stock Taillights
-Shaved Emblems
nj99solara
Postby Jai_Jai_Binks » Fri Sep 09, 2005 8:44 am
nice work, thankfully my grill's still not chipping yet....
Postby gone » Thu Sep 15, 2005 8:14 am
nice job, looks alot better
gone
