SolaraGuy.com • View topic - Some Random Updates UPDATED 4-24
Postby JamesT » Fri Feb 13, 2009 11:14 am
The Steering wheel, shifter, and the long seams on the seats were all sewn by hand (by me, of course).
New Head unit!
I decided to route the iPod cable into the center glovebox
Sanded and polished the Valve Cover
The Plenum is slowly getting the same treatment...
BespokeAutoInterior
JamesT
Shift Boot Master Crafter
Postby Biggi_e » Fri Feb 13, 2009 11:23 am
looks great
Postby solara1989 » Fri Feb 13, 2009 11:46 am
not bad. :drinking:
2000 Solara SLE V6 Diamond White
solara1989
Postby NVDIS1 » Fri Feb 13, 2009 11:57 am
:o looks great!...nice job!
Postby Chinky420 » Fri Feb 13, 2009 12:33 pm
how did you route the ipod to come thru the bottom of the storage console?
currently i have my ipod connect routed thru the center console, but in a way that has it come up thru the e-brake slot (so you always see the cord going into the center storage.
really, what i'm curious about is whether you had to remove the center console in order to do the cuts, or if you were able to cut a hole and run the wire while the storage console was still in the car.....?
looks good though.
Chinky420
Postby CamryOnBronze » Fri Feb 13, 2009 12:50 pm
looks clean james, i like the shifter cover- baller!!
Postby lilm » Fri Feb 13, 2009 1:03 pm
Chinky420 wrote:how did you route the ipod to come thru the bottom of the storage console?
looks good though.
why not just take the center console off its like 2 bolts and two screws......?
lilm
Postby akora12 » Fri Feb 13, 2009 1:27 pm
Very nice James, looks like a lot of hard work. I wish my valve cover looked like that!
Postby Jakecallun20 » Fri Feb 13, 2009 2:03 pm
looks good though.
Chinky, there are bolts around the inner piece of the console. Pull that out, and then remove the 2 screws for the center console under the shifter bezel and just pull up the center console piece a little bit, to get your hand under it, run the cable behind your AC and ashtray, under the shifter and under the cupholders. Then just drill a small hole in the bottom of the center console and voila. Done. Thats what I did.
Postby SleeperSolara » Fri Feb 13, 2009 4:40 pm
Looks good man.
How much would you charger to polish a valve cover??
Postby JamesT » Fri Feb 13, 2009 6:36 pm
Thanks for the compliments. A lot of time has gone into these projects...
looks good though.
I did remove the center console. It's easy enough to take out. Then I made a hole in the storage console. Eventually, I'll get a rubber gromment to go around the hole so it looks cleaner.
BespokeAutoInterior
JamesT
Postby JamesT » Sun Feb 15, 2009 1:22 pm
SleeperSolara wrote:Looks good man.
Thanks!
The easiest way would be for you to send me your valve cover (or I could get one from somewhere) and then I'll shine it up for you. I'm not sure of the price yet - I have no idea what would be fair.
BespokeAutoInterior
JamesT
Postby SleeperSolara » Sun Feb 15, 2009 10:08 pm
Thanks!
Oh, ok.
Postby JamesT » Fri Apr 24, 2009 10:18 am
Updated Photos:
BespokeAutoInterior
JamesT
Postby SleeperSolara » Fri Apr 24, 2009 10:53 am
Dang baller. :o
