SolaraGuy.com • View topic - PICS - Black Grill & V6 Emblems
Postby BLACK V6 » Thu Mar 19, 2009 5:17 pm
Just to start out I took these pics in my garage so no special backdrops or anything lol. Im all about having the shaved look, clean, without emblems, but I was just experiments and putting the V6 emblems on the fender actually looked good to me idk... And I painted my old grill black, nothing new, not sure if I will keep it on there. Should I put the chrome, stock grill back on or does it look ok. I know, I know, the pictures do it no justice.
BLACK V6
Postby TLMNICK » Thu Mar 19, 2009 5:24 pm
I kinda like the look of the gold emblems on the black paint.
You gotta drop that thing. It'd set your rims off nicely.
TLMNICK
Postby BLACK V6 » Thu Mar 19, 2009 5:33 pm
I know, I know. I think I have a phobia of rubbing. Idk what it is called but I have it. Any ideas on some lowering springs where I would not have to worry about rubbing? I have a tight budget so no fender rolling...
BLACK V6
Postby SleeperSolara » Thu Mar 19, 2009 6:41 pm
Looks good man.
Postby LEE337 » Fri Mar 20, 2009 6:44 am
Very nice!
If your looking for some good springs go with either Tein or Eibach.
If you have speakers in the trunk go with Tein it offers a lower drop in the front (1.7) that way with the weight of the subs it evens out.
If you dont have subs in the trunk, go with Eibach it offers an even drop all around (1.5)
Both are very good springs and in the range of $200-$300. 8)
Postby BLACK V6 » Fri Mar 20, 2009 3:05 pm
^^ Thank you. I have only one sub in the trunk, it dosent weigh much just a little JBL and a 200 watt amp. I dont want to have to worry about rubbing at all so im thinking eibachs.... Would I have to worry about rubbing? (im on 18's)
BLACK V6
Postby BLACK V6 » Fri Mar 20, 2009 3:09 pm
Could I install the springs myself? I do not have to have any special equipment or anything do I? I have access to a garage with lifts and things fyi. Thanks for any help...
BLACK V6
Postby BLACK V6 » Fri Mar 20, 2009 6:15 pm
Bump? Any help would be appreciated... ^^^^
BLACK V6
Postby TxBmbleBee » Fri Mar 20, 2009 6:19 pm
installing springs is not hard, i think there is a diy around here somewhere. you will need to go to autozone or something and buy a spring compressor tho.
TxBmbleBee
Postby LEE337 » Sat Mar 21, 2009 6:12 am
Yeah, installing springs is easy. You are gona need a spring compressor though. You should be able to find out how by looking through the tutorials or getcha a Haynes book. Of course afterwards your gona need an alignment. As for the rubbing issue, you shouldnt rub at all depending what size tires you have. What size are they???
Postby BLACK V6 » Sat Mar 21, 2009 6:23 am
^^ 225/45 ZR18
BLACK V6
Postby LEE337 » Sat Mar 21, 2009 6:28 am
Sweet! Thats the size Im gona run when I get my 18s. 8)
They shouldnt rub, but in hard cornering they might a little. Do you have a TRD RSB??? Do you plan on getting one??? They are super sweet!
Im on Teins and when I get my 18s I plan on rolling my fenders if I need to.
