SolaraGuy.com • View topic - 3000k 50w Foglamps - White?!
Postby Mr_Chunkz » Wed Jun 24, 2009 12:41 am
Hey guys
I just added a small mod to my TSX that would otherwise go unposted, but I decided to start a thread showing you what it is.
I bought some 50w HID foglights that are 3000k, or pure yellow.
The wierd part was that I installed these and when you look directly at the bulb, it looks white for some reason, but the light output is incredibly yellow. Whats up with that?
Heres some pics to show what I'm talkin bout.
The light reflected off my white garage door
The foglamps themselves look pretty white!
The passenger side fog, which isnt in direct line of sight, appears yellow again
The light from rear quarter view
The light from bang side on view
The light from straight ahead, slightly above the car. The fog lamps look white!!
http://s34.photobucket.com/albums/d109/Mr_Chunks/TSX/?action=view&current=TSXHID.flv
And to prove its not my camera taking crappy pics ( even tho my camera does take crappy pics ) here is a walkaround vid of my car.
I guess the effect can be explained that the 50w produces such an intense brightness, it washes out color inside the housing itself....
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby (K) » Wed Jun 24, 2009 1:25 am
Projector fogs?
(K)
Postby Mr_Chunkz » Wed Jun 24, 2009 1:28 am
(K) wrote:Projector fogs?
negative
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby (K) » Wed Jun 24, 2009 1:34 am
My bad, totally spaced out and forgot I posted that already...
Either way you got me stumped. I was going to say it's because of a cut-off shield but now I'm not so sure. Looks real good though.
(K)
Postby Mr_Chunkz » Wed Jun 24, 2009 1:36 am
the only explaination is that its because 50w is so bright and the foglamp is so small it intensifies and makes it white when viewing it dead on.....
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby (K) » Wed Jun 24, 2009 1:39 am
I'd assume it might have something to do with the fog housings and the bulb itself. Not suggesting you go out and do it, but if you change the brand of the bulb it MIGHT do something to it visually.
(K)
Postby Akfahad » Wed Jun 24, 2009 6:49 am
Tracy...just out of curiousity, are you running the same wattage for your headlights?
Postby mazen222 » Wed Jun 24, 2009 7:15 am
Looks cool man
1999, 5 Speed V6
mazen222
Postby Mr_Chunkz » Wed Jun 24, 2009 10:05 am
Akfahad wrote:Tracy...just out of curiousity, are you running the same wattage for your headlights?
no
the wattage on the headlight is stock 35
I simply replaced the bulb with a 6000k bulb
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby indiglosolara » Wed Jun 24, 2009 11:14 am
Tracy, The 3000k fogs doesn't matter what wattage will look white. The light will be yellow. I've used 3 diff kits and they were all like that..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby kpxboi0619 » Wed Jun 24, 2009 11:21 am
What brand do you have?
Im planning to replace my fog hid but since i have a yellow housing let's see how it would look on mine
kpxboi0619
Postby BLACK V6 » Wed Jun 24, 2009 1:26 pm
I think it looks fkin awesome like that. I wouldn't worry about it or try tinting your lenses yellow.
BLACK V6
Postby Mr_Chunkz » Thu Jun 25, 2009 1:11 am
kpxboi0619 wrote:What brand do you have?
Ive got a brand called XEbrite
They were an ebay brand but were a lil costly.....
The quality seems to be there. They dont buzz and hum like my other hid on my solara.
- Mr_Chunkz -
The Daily
Mr_Chunkz
Postby SleeperSolara » Thu Jun 25, 2009 11:55 pm
Looks good Tracy.
