SolaraGuy.com • View topic - OCD on details. *update II*
Postby SleeperSolara » Tue Nov 03, 2009 12:18 am
Well i got my camber kit installed finally, but then i also got my other stuff from Gabe in the mail and installed them also.
Also got my Whiteline 24mm front sway bar installed also.
Comparison of the OEM and Whiteline front sway bars.
Crap someone stole my rims wit my new tires. :(
Just kiddin' i was installin' the new camber kit. lol.
My new camber kit, i got installed, and then got my car aligned at my friends' work.
Now i won't have any camber issues on my new tires.
Next i installed replacement parts for stuff that had came wit my car.
Broken sideview mirror.....
Had that on the car for about 4 years, i got sick of it.
This is an older picture, but if you look at the center console piece, you can see 2 holes, 1 is in the sun and 1 is in the shade.
That came like that on the car.
I was again sick of that.
Now wit the semi-new stuff on my car.
Good sideview mirror thanks to Gabe.
It doesn't look shiny compared to my driver side, but it's not cracked is all i care.
New center console piece, wit no holes in them.
I even cleaned up the arm rest console piece.
Also installed a new switch for my interior lights.
It was a long switch, but i changed it to a slimmer rocker switch.
This is was my car looks like at nght when i flip the switch.
**update**
Got my sub-frame braces in today. :D
I was too excited to get them, i installed them this evenin'. lol.
Only took me a total of 3 hours, which included runnin' to the hardware store to get some new nuts and washers.
**update II**
Went to the salvage yard and picked up a new scissor jack sinced mine failed on me while i changin' out my spare. :o
Also got timin' belt cover that says 1MZFE also.
Even picked up my front heads i had pulled off a week ago.
Exhaust and Intake cam shafts and cam.
Front heads wit valve cover.
Timin' belt cover that says 1MZFE. :D
Should be pickin' up the rear heads i also pulled off soon.
Last edited by SleeperSolara on Wed Nov 11, 2009 12:02 am, edited 4 times in total.
Postby jetbtkng » Tue Nov 03, 2009 1:24 am
your gonna luv the front sway bar,& camber kit, those are the two best handling performance mods you can do, rear sway bar also, what did you set your camber at, mine 1.5 front, 1 rear............... :drinking:
Postby SleeperSolara » Tue Nov 03, 2009 8:01 am
jetbtkng wrote:your gonna luv the front sway bar,& camber kit, those are the two best handling performance mods you can do, rear sway bar also, what did you set your camber at, mine 1.5 front, 1 rear............... :drinking:
Oh i do man. :D
I'm tryin' to take is easy so i don't break the OEM sway bar brackets.
But i do feel a big difference though.
Yeah i just set my camber kit to O.E. specs.
Can't wait til my braces. :lol:
Postby LEE337 » Tue Nov 03, 2009 8:53 am
Lookin good John. 8)
We are gona have the best lookin Gen 1s at the Texas Meet!!! 8) :D
Postby Eye8Pussies » Tue Nov 03, 2009 10:56 am
looking clean! just take a high speed buffer to that light and it'll be nice and shiny just like the rest of the car!
Postby SleeperSolara » Tue Nov 03, 2009 1:00 pm
LEE337 wrote:Lookin good John. 8)
Thanks man.
Yeah.
Eye8Pussies wrote:looking clean! just take a high speed buffer to that light and it'll be nice and shiny just like the rest of the car!
Thanks man.
Actually the headlights are good.
I took the picture when it was like 12ish, so that's why the car looks weird.
Postby '_' » Tue Nov 03, 2009 1:48 pm
Looks good, I'm thinking about adding a FSB and possibly a camber kit..
'_'
Postby Toy1mzfe » Tue Nov 03, 2009 1:51 pm
Thats a thickass bar man.
Postby indiglosolara » Tue Nov 03, 2009 2:41 pm
looking good....
It kinda of weird but I have negative 1.2 degrees camber in the front using chmaber plates and -.75 in the rear but my tires are still wearing even.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Mr_Krispy1183 » Tue Nov 03, 2009 3:15 pm
indiglosolara wrote:looking good....
Kenny, with such settings, I'm sure your alignment tech also adjusted the toe angles to compensate for the camber to even out the tire wear as much as possible.
Postby SleeperSolara » Tue Nov 03, 2009 5:03 pm
'_' wrote:Looks good, I'm thinking about adding a FSB and possibly a camber kit..
Thanks man.
Toy1mzfe wrote:Thats a thickass bar man.
Yeah i know. lol.
The OEM is about 17mm, and the Whiteline is 24mm.
Wit the OEM front sway bar, it was so easy to pick up, wit the Whiteline it was heavier by alot.
Thanks man.
Yeah, For some strange reason my front passenger camber was -2.4, hence why i wanted to by a camber kit. lol.
But not i have my car alignment within O.E. specs.
Mr_Krispy1183 wrote:Kenny, with such settings, I'm sure your alignment tech also adjusted the toe angles to compensate for the camber to even out the tire wear as much as possible.
I agree.
Postby indiglosolara » Tue Nov 03, 2009 9:02 pm
Possible.. I didn't tell him to do anything except make it negative to the spec. So he probably did adjust everything else..
That front sway looks crazy!! I regret selling mine.. sold it for $80.00 bucks.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby SleeperSolara » Tue Nov 03, 2009 11:34 pm
Yeah i know. :lol:
Dang man.
Postby jetbtkng » Wed Nov 04, 2009 3:03 am
if you want your lara to handle like this, http://www.youtube.com/watch?v=1pLigAQIFzw camber 1.5 front 1 rear................... :drinking:
Postby SleeperSolara » Wed Nov 04, 2009 7:55 am
jetbtkng wrote:if you want your lara to handle like this, http://www.youtube.com/watch?v=1pLigAQIFzw camber 1.5 front 1 rear................... :drinking:
Thanks man.
I've watched your video from the track before.
It's very nice.
My sub-frame braces should be at my house soon. :angel:
