SolaraGuy.com • View topic - 2nd Video On YouTube!!!
Postby 99BlackSandv6 » Wed Jan 27, 2010 4:51 pm
Check out this video, I recorded it earlier today. Just driving around. :D
http://www.youtube.com/watch?v=FRR2y3oA ... _embedded#
New Video, with annotations. :P
http://www.youtube.com/watch?v=sPUuJNX8Wqw
Postby DriDed » Wed Jan 27, 2010 5:06 pm
Haha you should have gotten a manual if you wanted to shift the gears yourself. :D
I like the exhaust and the intake note from the inside of the car, its very nice.
+TRD front strut brace
+TRD rear sway bar
+Injen Short ram intake
+Pioneer DEH 2200 UB headunit
DriDed
Postby 99BlackSandv6 » Wed Jan 27, 2010 5:12 pm
Hey, you gotta take what you can get. Also, I am actually doing my own downshifts.
The exhaust note is awesome! Thanks. :D
Postby cartang » Wed Jan 27, 2010 5:35 pm
Nice video and sound :)
cartang
Postby SleeperSolara » Wed Jan 27, 2010 9:29 pm
Nice video man. 8)
Postby GTX » Thu Jan 28, 2010 6:04 am
I love how it sounds. Do you have a vid of how the muffler sounds from outside?
99 Camry LE V6
GTX
Postby GzNutz » Thu Jan 28, 2010 8:08 am
Nice vid!
Postby Ruski » Thu Jan 28, 2010 8:11 am
Nice video, Grip that steering wheel.
Postby 99BlackSandv6 » Thu Jan 28, 2010 2:54 pm
GTX wrote:I love how it sounds. Do you have a vid of how the muffler sounds from outside?
I don't, but I can make one. Maybe Sunday I'll be able, but it sounds best under load. It's not the same when it's just sitting there being revved.
Thanks for the compliments guys! :D
Postby GTX » Fri Jan 29, 2010 12:47 am
Is it very loud on the outside? I've been looking for a muffler that has a nice, sporty tone to it but doesn't look or sound obnoxious. The GReddy Evo muffler sounds great but looks too big, and the TRD muffler is the other way around.
99 Camry LE V6
GTX
Postby 99BlackSandv6 » Fri Jan 29, 2010 9:22 am
Well, I don't think it's that loud. I can cruise around and be pretty much as quiet as stock, but when I get on the throttle it screams pretty good. I definitely don't think it is obnoxious. I still have all the factory piping before the rear muffler, so the tone is nice and deep, and not too loud. I definitely recommend Magnaflow mufflers. I'll try to get a video of the sound from the outside. Maybe I'll be able to do that this week. The video shows the sound of the car very accurately.
Postby antoraa » Tue Feb 02, 2010 3:52 am
How can I get to YouTube in school even though they block the proxy sites?
My school blocks the proxy sites needed to get to YouTube. Anyone know another way to get to it?
antoraa
Postby 99BlackSandv6 » Tue Feb 02, 2010 2:04 pm
No idea. Just go home. :D
Postby solara90 » Tue Feb 02, 2010 4:02 pm
i always wondered.. is it bad for your tranny to shift like that or from 1-2-D.. ive done it a few times
02 solara 2az
solara90
Postby 99BlackSandv6 » Tue Feb 02, 2010 4:58 pm
Nope, if you read your owner's manual I think it shows the maximum speed for a given gear. As long as you don't exceed that, you'll be fine.
What I generally do when I am in a 'spirited' driving mood is as follows:
From a stand still, shift into 2. Hold it in 2 and let it shift through 1st into second. It will not go into 3rd under about 78mph. When you get going and start to hold your speed, you may as well just put it into D and let it do its thing. When you get to a turn, (depending on the situation) you should be alright to shift into 2 from about 40mph (even up to 65 is doable, but I don't recommend it for you if you haven't tried before). If you don't need to slow to that speed, just bump it out of O/D. That should provide sufficient slowing. I usually tap the throttle to "rev match" so that there is less shock to the transmission. I can make a video to show this stuff if you think it would be helpful. 1st gear is only usable up to about 34mph, you should just avoid using it unless it is from a stand still. Even going into L from about 25 jolts the drivetrain pretty good, and tends to shift weight pretty dramatically.
To those of you with 5-speeds, I know that I don't have to shift my auto. Don't tell me that. I know. And I do also know how to drive stick, so don't think that you're better than me. :lol:
The reason for doing so is to keep the car in lower gears so that the engine and gearing assists in braking. Also if the car is in 2nd going into a turn it won't be down-shifting when exiting the turn. This keeps the car from getting upset, due to weight shift and sudden changes in wheel speed. And instead of having my foot on the brake, it can be on the throttle ready to push out of the turn. Since my foot stays in position on the throttle more of the time I can use throttle to adjust for understeer/oversteer through the turns.
If you rode with me you would understand. I'm not that great at explaining it, but you get the idea. I might try to make a video in a location that makes this technique more obvious. So you guys can see what I'm talking about.
-Ben
