SolaraGuy.com • View topic - Removing door panels
Postby geminimouse » Mon Jul 19, 2004 9:55 pm
Pry off the plastic sail piece.
Pry off the cover to expose a screw near the front of the door.
Pry open the little cover to expose another screw next to the lock.
Put a flat head screwdriver between here...
And push the screwdriver up till u hear the clip release.
Then put the screwdriver between here...
And push the screwdriver down till u hear the clip release.
You should be able to take out the plastic surround.
Take out the little carpet piece and expose a screw.
After getting the screw out, pry the cubby hole thing out. **Start prying clips from the back first then pull the whole thing towards the rear to get it out**
Disconnect harnesses. Passenger side has 2 harnesses and driver side has 1.
You should know what to do with these...
Starting from the bottom of the door panel, pry off the clips...there's about 7 altogether.
Then lift the panel up a little to get it off.
Remove the harness for the tweeter and the door panel should be completely off.
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby Hsakuragi » Mon Jul 19, 2004 10:18 pm
haha..good one!
Hsakuragi
Postby oompah2788 » Thu Jul 22, 2004 4:49 pm
Thanks man! Im going to be installing some new speakers too so i needed this.... the other one just didnt seems as well detailed..... this has all the pics for each step . Thanks again! :D
oompah2788
Postby Jon11582 » Thu Jul 22, 2004 5:12 pm
The par with the handle was the hardest part for me when I did it. Thanks for the writeup.
2000 Black Solara SE
Jon11582
Postby MalBandito99 » Thu Jul 22, 2004 6:03 pm
yargh...monkey.
:lol:
MalBandito99
Postby ~Spadwaller~ » Sun Apr 09, 2006 2:15 am
Where did the pictures go?
~Spadwaller~
Postby geminimouse » Sun Apr 09, 2006 5:44 am
~Spadwaller~ wrote:Where did the pictures go?
up
08 Accord Coupe
geminimouse
Postby scLara626 » Sun Apr 09, 2006 8:34 am
they must make the newer solaras a lil different now, they have an extra screw...
" I heard (YOUR NAME GOES HERE) got fired from the sperm bank for drinking on the job''
scLara626
Postby NeFaRiOuS_SLE » Fri Apr 21, 2006 12:48 am
scLara626 wrote:they must make the newer solaras a lil different now, they have an extra screw...
I guess he missed one. However, I've read a lot of resources, but I never found out how to remove the door handle when I was trying to at least disconnect a blown speaker on the right side (which kicks in every now and then)... Just to think I was going to take it to a pro in a few weeks; thanks for the tutorial!
Postby geminimouse » Fri Apr 21, 2006 5:50 am
ignore him..he has a gen2
08 Accord Coupe
geminimouse
Postby SleeperSolara » Fri Apr 21, 2006 7:16 am
Nice write up man.
Postby Akfahad » Fri Apr 21, 2006 7:48 am
definitely good write up
Postby xSxOxLxAxRxAx » Mon Sep 25, 2006 1:54 pm
Damn it woulda been nice if I knew this was here 2 weeks ago, damn circuit city charged me 100 bux for install of new speakers
18" ADR Rydox wrapped in michelin pilot sport, Alpine HU, 2 12" kickers, Cold-air intake, viper 900
xSxOxLxAxRxAx
Postby 99sle » Sun Mar 16, 2008 9:53 am
I cant get the pics to show up. Can someone repost them?
99sle
Postby SolaraHop » Sun Apr 20, 2008 8:12 pm
same here, I need to take my door apart but pictures gone :(
SolaraHop
