SolaraGuy.com • View topic - OFFICIAL GEN 1-1.5 AFTERMARKET PARTS LISTING
Postby Midias » Tue Jan 08, 2008 8:50 am
I think this should be a sticky
TRD Section
TRD (www.trdusa.com) or PM NVDIS1 or (www.trdsparks.com):
Front Strut Tower Brace (Discontinued)
Supercharger 3.0l V6 (Discontinued)
Rear Sway Bar (PTR06-06990-10)
Sports Muffler (PTR19-06990-03)
Lowering Springs (1.2 / 1.4) (PTR07-06990-SL)
Air Filter 2.2L, 2.4L, 3.0L I4 and V6 (PTR05-06990-01)
Cleaning kit for all TRD air filters (PTR05-00000-CL)
TRD Radiator Cap (PTR04-00000-02)
TRD Thermostat 2.2L (PTR04-00127)
Short Shifter
Short Shifter Section
TWM (http://www.twmperformance.com)
Short Shifter - 2" height reduction - 35% throw reduction
Ralco RZ (http://www.ralcorz.com/)
Short shifter (914938)
K&N Oil Filter Section
K&N (www.knfilters.com):
Oil Filter 2.2L, 2.4L I4 (HP-1003)
Oil Filter 3.0L V6 (HP-1002)
Oversize Oil Filter 3.0L V6 (HP-2009)
Ignition Section
Ignition Solutions (http://www.okadaprojects.com/usa/home.htm)
High Powered Coils
2.4L 2AZ-FE Coil-Over Plug Direct Fit (PD4003701R)
Magnecor (www.magnecor.com)
Wires 8mm 7mm 8.5mm
3.0 V6 60212 67212 65212
2.2 I4 40298 47298 45298
NGK (www.ngksparkplugs.com)
NGK IX iridium 3.0L V6 NA (BKR6EIX-11)
NGK Premium wire set 3.0L V6 (TE65)
NGK IX iridium 2.2L I4 (BKR6EIX-11)
NGK Power Cables 2.2L I4 (10T)
NGK Premium wire set 2.2L I4 (TE58)
NGK IX iridium 2.4L I4 (BKR6EIX-11)
Weapon R (www.weapon-r.com):
Ignition Equalizer Kit 2.4L I4 (960-113-101)
Misc Performance Section
Over Bore TB (http://www.proflowdesign.com/tbtoy.html)
Toyota Solara 1MZ-FE 3.0L V6
Price $175.00
UNORTHODOX (http://www.unorthodoxracing.com/)
ULTRA S CRANK PULLEY 2.2L (021210102)
URD (http://www.urdusa.com/)
Crank pulley 3.0L V6 (discontinued)
Throttle Body Spacer (www.hubcapsplus.com)
Helix Power made for Tacoma 3.4L V-6 fits 3.0 V6 (SPE-34055)
Use coupon code HELIX
Or
Throttle Body Spacer (www.summitracing.com)
Powr-Flo for Tacoma 3.4L V-6 fits 3.0 V6 (62133)
Requires 2 new bolts from home depot. You need 2 M8 X 1.25 70mm and 2 M8 Washers for top. For the bottom use the 90 mm screws that came with the kit and 2 washers under each.
Throttle Body Spacer (ebay.com)
OBX made for Scion TC 2.4L I4 fits 2.4 I4 (SPE-97220)
Jet ECU upgrade (http://www.jetchip.com)
99-06 Solara All Engines All Trans (65003)
KNOCK SENSOR UPGRADE (http://www.atsracing.net)
http://www.atsracing.net/ats_racing_knock_sensor.htm
Replacement Sensors Wells SU 121 or Borg warner S 8803
(1997 Camaro 5.7L knock sensor)
Unicersal Oil Catch Can (www.ebay.com)
For all engines
Oil Catch Can LINK
Intake Section
Note on intakes CPE is the best choice as far as power is concerned. No one makes a true CAI and the ebay intake is crap.
eBay (www.ebay.com)
Ebay Generic 2.2L I4
Intake 3.0L V6 DON'T BUY THIS
Custom Performance Engineering, CPe (www.cp-e.com):
Short Ram Intake With ECU upgrade MAFci Kit, 3.0L
Average gains of 14.7 wheel hp and 15.4 wheel ft lbs.
Peak gains 17.5 wheel hp and 20.1 wheel ft lbs.
Larger K&N filter upgrade for CPE
K&N Filter Number: E-0773
Secret Weapon Intake System 2.2L I4 (305-120-101)
Dragon Intake System 2.2L I4 (805-120-101)
Secret Weapon Intake System 2.4L I4 (305-144)
Dragon Intake System 2.4L I4 (805-144)
Secret Weapon Intake System 3.0L V6 (305-129-101)
Dragon Intake System 3.0L V6 (805-129-101)
Injen (www.injen.com):
Short Ram Intake 2.4L I4 (IS2025BLK or IS2025P)
Short Ram Intake 3.0L V6 (IS2030BLK or IS2030P)
Short Ram Intake 2.2L I4 (IS2020P)
Air Filter 2.2L, 2.4L, 3.0L I4 and V6 (33-2219)
Typhoon Kit 2.4L I4 (69-8609TTK)
6.4 HP @ 5600 RPM
Air Filter 3.0L V6 (33-2145-1)
OBX (www.obxracingsports.com, ebay)
Intake 2.75 inch 3.0 V6 (OB10353)
Exhaust Section
JP Performance (http://jpheadersexhaust.com)
JP Headers 3.0L V6 (JP-1MZFEhd)
JP Headers 2.4 I4 (No part number listed call)
JP 3 Inch Cat-Back (JP-1MZFEScb)
Ebay Headers (www.ebay.com)
Unknown manufacture
3.0 V6 with test pipe
Greddy (www.greddy.com)
Greddy Evo 2 Cat-Back 3.0L V6 (GRD-10116601) Discontinued
Apexi (http://www.apexi-usa.com/)
APEXi World Sport Cat-Back 3.0L V6 (104-KT02) Discontinued
OBX Racing (www.ebay.com)
For Camry and Solara V6 3.0L 3" pipe
Headers for 99-02 Solara uses resonator instead of a converter.
Header for 97-01 2.2 camry could be adapted for solara.
V6 Header install
viewtopic.php?t=45220
JIC-Magic (www.jic-magic.com)
All Engines
DE Type 1 ST Catback (MCV20D1-ST)
DE Type 1 Sus Catback (MCV20D1-SU)
Megan Racing (http://www.meganracing.com)
All Engines 2.5 inch piping
OE performance style non fart cannon ( MR-CBS-TSO99V6OE)
Drift Spec Z N1 style muffler (MR-CBS-TSO99V6DS)
Suspension Section
Eibach (www.eibach.com)
Lowering Springs All Engines (8258.140) (-1.6" / -1.6")
Tein (www.tein.com/)
Tein S Tech Lowering Spring All Engines (TEN-SKL16-AUB00) (-1.7" / -1.4")
Tein Coilovers (DSL16-KUSS2)
Lowering springs all engines (MR-LS-TCA97) ( 2" Front, 1.7.5-2" Rear)
Street Series Coilovers (MR-CDK-TS99) (ride height and 32-way rebound adjustment, front camber plates)
KYB (www.kyb.com)
GR-2 All Engines
Right Hand Front (334245) Rear (334133)
Left Hand Front (334246) Rear (334134)
Tokico (www.tokicousa.com)
Tokico HP All Engines
Right Hand Front (TOK-HB3185) Rear TOK-HB3182)
Left Hand Front (TOK-HB3184) Rear (TOK-HB3181)
JIC-Magic(www.jic-magic.com)
All Engines
Front Strut Tower Bar aluminum (OAS-MCV20-F)
Front Strut Tower Bar Carbon Fiber (TBA)
FLT-TAR Coilover System (MCV20FLTA2)
FLT-FAS Coilover System (MCV20LFLTA1)
Whiteline (www.whiteline.com), (http://www.globalperformanceparts.com)
All Engines
Sway Bar Front (BTF38) 24mm
Sway Bar Rear (BTR39) 20mm
Front Springs (73119)
Rear Springs (78600A)
Strut Tower Brace (KSB508)
Energy Suspension (www.energysuspension.com)
99-03 All Engines
Front End Control Arm Bushing Set (8.3117)
Rear End Control Arm Bushing Set (8.3118)
Front Sway Bar Frame Bushings 18mm (9.5122)
Front Sway Bar Frame Bushings 19mm (9.5123)
Rear Sway Bar Frame Bushings 16mm (8.5120)
Ultra Racing (www.nextgentuning.com)
99-03 All Engines
4-point lower tie brace (part# UR-LA4-366)
Rear lower member brace 2 pc. (part# UR-RL4-614P)
Transmission Section
ACT (www.advancedclutch.com)
ACT Modified Street Clutch Disc 3.0L V6 (ACT-2000604)
ACT XTreme 4-Pad Solid-Center Race Clutch 3.0L V6 (ACT-4236007)
ACT XTreme 6-Pad Solid-Center Race Clutch 3.0L V6 (ACT-6236007)
Exedy (www.exedyusa.com)
OEM Replacement clutch
1999 - 2001 SOLARA BASE L4; 2.2L; Gas 5SFE (16073)
1999 - 2002 SOLARA BASE V6; 3.0L; Gas 1MZFE (16062)
Fidanza (www.fidanza.com)
Lightweight Flywheel V6 Manual ONLY 1MZFE (130881)
Postby d4008 » Tue Jan 08, 2008 9:25 am
how do you make it a sticky. i found another website for the RSB it www.trdsparks.com its 150$ there.
its almost done, cant wait til spring.
d4008
Postby LatinUSMC » Tue Jan 08, 2008 10:54 am
^^^^^^^^a couple of good TRD items:
http://www.trdsparks.com/displayparts.p ... rts_id=236
LatinUSMC
Postby Jakecallun20 » Tue Jan 08, 2008 11:11 am
Thanks Midias. I didn't know that the 5VZ-FE 3.4 TB spacer would work with 1MZ-FE 3.0. Ima look into getting that. 8)
Postby Midias » Tue Jan 08, 2008 12:50 pm
d4008 wrote:how do you make it a sticky. i found another website for the RSB it www.trdsparks.com its 150$ there.
A mod has to make it a sticky
Postby lexmex » Tue Jan 08, 2008 1:03 pm
Also a K&N HP-2009 oversized oil filter will fit on the 1MZFE engine. There is also a TRD Radiator Cap and Thermostat. Of course there used to be the URD crankshaft pulley.
lexmex
Postby Midias » Tue Jan 08, 2008 2:14 pm
lexmex wrote:Also a K&N HP-2009 oversized oil filter will fit on the 1MZFE engine. There is also a TRD Radiator Cap and Thermostat. Of course there used to be the URD crankshaft pulley.
Added how could I forget the pulley I think Greg and I are the only owners on this board. Man this is a nice list about time someone got off their lazy ass and made one.
So anything to add let me know.
Postby SolAraB » Tue Jan 08, 2008 3:10 pm
^^^^^This thread is awesome....thank you!! :D
V6 5Spd....Injen W/CAE, Denso Ik22, Ngk Blues, TB Spacer, Twm SS, and of course CEL
SolAraB
Postby Midias » Tue Jan 08, 2008 6:14 pm
SolAraB wrote:^^^^^This thread is awesome....thank you!! :D
I thought with the questions being asked so often it would be a good idea.
Postby d4008 » Tue Jan 08, 2008 8:52 pm
throttle body spacers, how much HP gains are we talkin cause those things cause about 300$ right.
d4008
Postby Jakecallun20 » Tue Jan 08, 2008 8:56 pm
d4008 wrote:throttle body spacers, how much HP gains are we talkin cause those things cause about 300$ right.
If you had checked it out before you posted, then you would know that they are only 79.99 for the Tacoma TB. It is listed above. The item description tells you the gains.
Postby d4008 » Tue Jan 08, 2008 9:04 pm
o i found one on andysautosport.com for 300$ bucks. maybe that was just the top of the line TB. anyway so how much. and i dont drive a tacoma are the parts interchangeable or something. So how much HP.
d4008
Postby CamryOnBronze » Tue Jan 08, 2008 9:27 pm
toss the twm short shifter on there if you get bored... I didnt know JP redid their site, I just thought it was down... thanks for updating me on that midias!
Postby d4008 » Tue Jan 08, 2008 9:38 pm
okay most of the stuff is looking like 15-20 hp for a tbs but im not so sure. anybody actualy got 1.
d4008
Postby SleeperSolara » Wed Jan 09, 2008 1:28 pm
I got one on my car.
Not that much of a difference....
