SolaraGuy.com • View topic - Sorry for the new-B question
Postby System_Crash » Tue Apr 07, 2009 6:08 am
Sorry for the new-B question (first yoda I've owned) but when changing my spark plugs on the v6 3.3 is there any gaskets I'm going to need to change/ ruin when I start pulling the intake off to reach the rear plugs?
and YES I did try the search/stickys and NO I didn't find any answers.
Pearl White 2004 Solara V6 90,000 miles
System_Crash
Postby D-money » Tue Apr 07, 2009 10:08 am
im pretty sure they make a tool for changing the plugs so you dont have to take off the intake manifold but if you do i reccomend also changing the valve cover gaskets while you have it off. you will need a new gasket for the intake manifold
D-money
Postby System_Crash » Tue Apr 07, 2009 10:29 am
Anyone know of this tool? when I had the engine cover off a few days ago It seemed pretty crowded in the back of the engine compartment. almost seems you would have to atleast pull the plenum
System_Crash
Postby D-money » Tue Apr 07, 2009 10:52 am
D-money
Postby System_Crash » Tue Apr 07, 2009 4:42 pm
Ok, well as expected I don't think I can get the rear plugs with a swivel plug socket, any tips, tricks anyone would like to share? There is no way with all the people on here , noone has changed their spark plugs in a 3.3 v6 come on guys ......
System_Crash
Postby CosmicGrooves » Tue Apr 07, 2009 5:50 pm
I'm not sure anyone here with a Gen2 has enough miles to be concerned about changing the plugs. Don't they last 100k miles?
CosmicGrooves
Postby Ilovemylara » Tue Apr 07, 2009 5:56 pm
Well with my 1mz-fe 3.0, (same block layout as your 3mz-fe 3.3) the best way i found was to insert a small extension with the socket on it, then once its seated on the plug, insert the longer extension then connect rechet and your good to go. Simply reverse the process for spark plug insertion.
Postby aleki2424 » Tue Apr 07, 2009 6:29 pm
Ilovemylara wrote:Well with my 1mz-fe 3.0, (same block layout as your 3mz-fe 3.3) the best way i found was to insert a small extension with the socket on it, then once its seated on the plug, insert the longer extension then connect rechet and your good to go. Simply reverse the process for spark plug insertion.
Thats exactly how i did it coz its a little tight to reach. I doubt that theres a big difference between the location
They sell the extensions as a set of three, at autozone or oreillys in addition to the plug socket. If you don't feel like buying you could rent them from autozone for free.
aleki2424
Postby System_Crash » Wed Apr 08, 2009 9:18 am
Well hell, I guess I'll bite the bullet and give it a shot
System_Crash
Postby System_Crash » Wed Apr 08, 2009 5:52 pm
Ok well took me about an hour and a half to do it but I did finnaly get the new plugs in. I DID have to take off the idle air control valve assemby and the pcv/crank case breather hose inorder to reach them. PS when you go to pull the wiring harness off of the coil DO NOT use the "push button" I snaped one off and it never worked as designed. Had to pry them up with a pick/screwdriver. for future refrence the driver and passenger side coils did not have to be disconnected from the wiring harnes (just wedged out of the way) BUT the one in the middle did inorder to remove it from the plug hole. The origional were denso went with NGK laser iridium and man were the old ones nasty! (Probly all that damn ethonal in the gas now) I'll try to post some pics in a few days.
System_Crash
Postby youngblood » Thu Apr 09, 2009 3:43 pm
Could you post a pic showing the old plugs? I'd love love to see what they look like with those miles. My '04 3.3l has 66,000 miles so your picture(s) would be very helpful for me to figure out when to change my plugs.
Black 2004 Solara SLE V6
Green 2002 Camry LE I4
youngblood
Postby Biggi_e » Thu Apr 09, 2009 3:47 pm
CosmicGrooves wrote:I'm not sure anyone here with a Gen2 has enough miles to be concerned about changing the plugs. Don't they last 100k miles?
theres no need to really change your plugs till you hit near 100k. i changed mine at 99k. im now at 103k
Postby System_Crash » Fri Apr 10, 2009 10:17 am
True they don't need to be changed till 100k But I purchased the car used with 82000 on it and wasn't sure what kind of care the engine had till I got it.
By the way what photo host site does everyone prefer? photo bucket?
System_Crash
Postby System_Crash » Mon Apr 13, 2009 6:34 am
So note these are at 84,000 miles
System_Crash
