SolaraGuy.com • View topic - Leather seats UPDATE PICS PG2
Postby Ruski » Tue Nov 10, 2009 7:27 am
Hey guys how hard is it to reupholster stock cloth seats with leather. The leather is a replacement . i was wondering how hard it is to put it on the seats and secure it properly. and what tools i may need
Thanks guys
Postby JamesT » Tue Nov 10, 2009 8:45 am
You'll need hogrings and hogring pliers (or needle nose). It's not easy to get the new covers on (at least the first few times). Do one seat at a time so you can reference the other seat when you put the new cover on.
If you don't want to use hogrings, zip ties and a awl work just as well.
BespokeAutoInterior
JamesT
Shift Boot Master Crafter
Postby kenny6683 » Tue Nov 10, 2009 10:41 am
you need to heat up the leather as well so that it stretches easier and you can put it over the seats...use heat gun. The only hard part about this is obtaining the leather
kenny6683
Postby JamesT » Tue Nov 10, 2009 11:19 am
kenny6683 wrote:you need to heat up the leather as well so that it stretches easier and you can put it over the seats...use heat gun. The only hard part about this is obtaining the leather
That's the easiest part!
Ruski, are you making the covers yourself?
BespokeAutoInterior
JamesT
Postby Ruski » Tue Nov 10, 2009 1:31 pm
Nope. Just looking to how hard a self install in. On my gen 1 I've pulled the cloth off but never installed leather before
Postby Ruski » Tue Nov 10, 2009 6:40 pm
Postby JamesT » Tue Nov 10, 2009 6:50 pm
Nice!
Just remember, leave one seat assembled so you can reference it while you are working on it.
BespokeAutoInterior
JamesT
Postby Ruski » Tue Nov 10, 2009 6:53 pm
yea im going to start with the back seats first to get a hang of it , then work my way up front
Postby kenny6683 » Tue Nov 10, 2009 8:22 pm
thats nice...I want to see when you're done
kenny6683
Postby dug320 » Tue Nov 10, 2009 8:40 pm
Reupholster? Do you mean covers as in the previous link?
If yes, this is what you need for tools.
Hog clips and hog nosed pliers.
Heavy duty wire cutters.
Can of silicone lube spray (helps slide the covers on).
12mm and 14 mm sockets and a Phillips screwdriver.
Utility knife.
It is not a hard undertaking. Takes time and patience.
dug320
Postby JamesT » Tue Nov 10, 2009 9:49 pm
dug,
do you do upholstery?
BespokeAutoInterior
JamesT
Postby Ruski » Wed Nov 11, 2009 1:05 pm
thanks Dug and JamesT for the info and tips, the leather should be in some time next week. im going to start pulling my seats out sometime this week.
Postby dug320 » Wed Nov 11, 2009 6:23 pm
I don't do it professionally just done a lot. My apologies for the length of the posting.
Take your time. It is not rocket science. You are trying to duplicate what was there in cloth not re-create in leather. There is a fair amount of give in the leather.
If you want heated seats this is a good time to install them. I have them and love'em.
Pull the back seat first. If there are side bolsters (can't remember if this car has them) the leather is attached with 1/4 staples.
Basically it is a pull off and put on.
To do the front seats remove from the car the passenger seat first and remove the seat portion (four bolts underneath). Pull the head rest. The headrest will be tough to recover as it takes a bit of force and a bit of silicone spray on the foam to help adjust. Leave the back attached to the frame. Cut the three hog clips on the bottom for the back and pull the cloth cover up and off. Remove the metal rod from the old cover and put in the new. Reverse the order for the leather install.
For the seat portion cut the hog clips underneath (I think there are three at the back and two or three for each side). At the front are bendable clips and pry them up to pull the covers. Pull up the sides of the cover off the frame to expose the 6 hog clips attaching the cover to the seat. It is not easy to do this so be patient. Cut the clips and remove the cover. Notice how the metal rod is oriented in the old cover and put it in the new cover the same way. The hardest part is lining up the spots to put the hog clips back. If the new leather covers are used, use the spots from old holes. If they are new it will be a little harder. There are two ways to line up the holes. One is to duplicate the holes from the cloth by lining up the old cover holes with the new (easy) and marking the location. The other (more professional, but who cares it will be hidden if you make a mistake) is to line up the rods in the cover in the slot in the foam and attach. Either way start on one side at either the front or back and then do the middle then the last. Do the other side in an order that works for you. It is kind of awkward so be patient. Once you get the 6 inside done you can pull the cover over the frame re-attach the rest. Notice the flaps on the corners, you do have to pull them kind of tight to get them into position. Remember you are duplicating what was in cloth so don't invent or innovate.
The drivers seat is similar. The biggest challenge is the lumbar support (if you seat has the feature, it is the lever on the right of the seat) and the power switches, again if your seat has the feature). If not then it is the same procedure as the passenger.
If your seat has the features, check to see if the leather covers already have the cuts made for the features. If they have the cuts it is simple, if not then you will need a very sharp utility knife. You can simply duplicate the holes using the cloth cuts as a template or put the covers on and then cut holes at the spots need. The seat cut for the power seat is a straight forward x. The lumbar cut is simple but take your time, it is easy to put it in the wrong spot or make it too large. The hole should be a simple x or use a leather punch.
Sometimes the covers do not have the holes for the head rests. If not, install the covers. On the top of the seat feel for the holes for headrest and with a very sharp utility knife cut a small x at each hole.
I hope this works for you. If I have forgotten anything please ask.
dug320
Postby unbalancedwood » Sat Nov 14, 2009 9:53 pm
GET ON IT!
unbalancedwood
Postby Ruski » Sun Nov 15, 2009 9:53 am
Question: Im now looking into heated seats, will the elements bend to the design of the seat since the gen2s have a crease in the middle of the seat. will the element take shape of that? and what can i use as a power source ?
