SolaraGuy.com • View topic - Another CE light.
Another CE light.
Another CE light.
Postby SolaraT » Sun Jul 11, 2004 6:07 pm
So I installed my Glow Gauges with the help of Rene (thatonemexguy) :D
I had to leave and finish the installation at home so I drove home without the cluster hooked on. :-? No major issues. Got home. Finished instalation and low behold that CE light was on!!!
Anyone know if I blew something up or can I just check and clear the code and expect it to go away forever?
Thanks,
Louis
SolaraT
Solaraguy need mo power guy
Postby krawzyazn » Sun Jul 11, 2004 6:09 pm
its cuz you took out the cluster
Postby SC V6 » Sun Jul 11, 2004 9:53 pm
no its not.. I've had my cluster out and started the car.. its not because of the cluster being out
SC V6
Postby Hsakuragi » Sun Jul 11, 2004 10:11 pm
^ i've been driving without it
Hsakuragi
Postby groovespacer » Sun Jul 11, 2004 10:20 pm
f*ck computers in cars..
so dam sensitive.
groovespacer
Re: Another CE light.
Postby JoeB » Mon Jul 12, 2004 5:28 am
solarat wrote:Anyone know if I blew something up or can I just check and clear the code and expect it to go away forever?
Louis, the only real way to know is to scan the code and see what is going on. There are many codes that you can scan that once cleared won't come back if it was a temporary situation. -JoeB
JoeB
Postby Ford_Fixorrepairdaily » Mon Jul 12, 2004 8:23 am
try to disconnect your battery? not sure if it will work, but it did for me
Postby SolaraT » Mon Jul 12, 2004 8:24 am
Thanks Joe and everyone.
I'll scan it up and get the reason. Post it here for clarity to this situation.
SolaraT
ford_FixOrRepairDaily wrote:try to disconnect your battery? not sure if it will work, but it did for me
I'll try that first. Thanks!
SolaraT
Postby SolaraT » Tue Jul 13, 2004 2:36 pm
for the record...the CE light is now GONE!
It went away by it self. As I was going to try and fix this (Battery)^ I noticed it was gone.
Thats a relief!
I'm still going to run the scan in case there are stored codes that I can clear out. Going to use Digimoto software with their OBDII kit. Waiting for delivery.
:D
SolaraT
Postby JoeB » Tue Jul 13, 2004 3:04 pm
That's a great idea. The code should still be stored and you can find out what was going on. It might be something you need to look into. I got a code saying my cat was inneficient, then it went away on it's own. I checked my a/f mixture and found I was running VERY rich. After retuning, I haven't had the code again. Let me know if you try dyno runs with the Digimoto. I couldn't ever get a usable reading. -JoeB
JoeB
Postby SolaraT » Tue Jul 13, 2004 3:12 pm
Sure will. Yeah I'm sure I need to feed it the most acurate numbers so I'll do my best.
I'm curious to get the sensor readings also and am very curious on the code I'm going to pull.
I'll let you know.
Thanks,
Louis
SolaraT
