SolaraGuy.com • View topic - Shifting on an Automatic - Racing ???
Postby 99V6solaraSE » Sun Jul 18, 2004 8:26 pm
Does it even help to Shift around on an automatic from L > 2 > D or to even downshift when racing ??
99V6solaraSE
Postby krawzyazn » Sun Jul 18, 2004 8:46 pm
yes cause you can redline the hell out of it :drinking:
Postby Mole » Sun Jul 18, 2004 9:58 pm
by doing so, it also shortens the life of the tranny.
i've done it a few times, but oh well...
Postby hari-bhari » Mon Jul 19, 2004 10:12 am
if you floor your car while racing, it will shift at optimum points anyways. taking it to redline or further in L, then shifting into 2, doing hte same, and then putting it into D, will just make you slower. not to mention the risk of damaging your engine and tranny. also for downshifting, its better to floor it and let ur ecu take care of the shifts, because if you are going 60 and all of a sudden put it into '2', you will blow your engine. overall not a good idea. only time u should use L and 2 is for ascending or descending steep hills.
hari-bhari
Postby 99V6solaraSE » Mon Jul 19, 2004 10:38 am
i mean i myself noe as for downshifting whether or not its gonna redline. Obviously i wont downshift if i wuz goin 80. I agree and i understand wut ur sayin and everything but there are those few occasions where even when i floor it and the car will juss stay in gear and takes forever to gain speed. Thats why i downshift to 2 or even L sumtymes. As for shifting times i think its still the same... its not slower or anything juss a matter of if u noe when to shift it, unless u forget to shift and it redlines for a while.
Does starting in L improve performance off the line? It seems as if it has more of a torquier feel. I dunn0 maybe its juss me.
99V6solaraSE
Postby krawzyazn » Mon Jul 19, 2004 10:42 am
umm when you down shift in an auto if your going too fast the ecu will not let it down shift say your going 80 and down it to 2nd it will shift when it is at a safe speed try it you can;t blow your engine
Postby 99V6solaraSE » Mon Jul 19, 2004 10:47 am
yah dats tru... i wuz juss about to say that LoL :D
but its possible that u might juss shift rite b4 redline and end up redlining it as well... its happened to meeh <<<
99V6solaraSE
Postby hari-bhari » Mon Jul 19, 2004 11:03 am
99sOLaRaSEaUto wrote: As for shifting times i think its still the same... its not slower or anything juss a matter of if u noe when to shift it, unless u forget to shift and it redlines for a while.
well i used to have an I4 auto like you, and i noticed when i shifted up from L->2 or 2->D, there was a lag for the shift, its not as quick as a manual shift. so any 'perfect' timing you may have will be thrown off. the only time (other than hills) that i can think of where its good to leave it in a lower gear, is if ur wanting to race some guy, and ur going slow cuz want him to catch up to you first, and then punch it, it would be good to keep it in a lower gear so you dont have to wait for the downshift before you take off.
as for leaving it in L off the line, it doesnt give you any more power, its just in your head. its prolly just that when you let off the gas, it has the feel of that manual, slowing down on its own, and then the throttle is really responsive when you touch it because its still in first gear. overall you're not really getting anymore power. its the same thing when people think theyre getting more 'traction' when they turn their overdrive off.
hari-bhari
Postby 99V6solaraSE » Mon Jul 19, 2004 1:15 pm
by the way i have a v6 sE... but yah i see wut your sayin
99V6solaraSE
Postby ICrazyChrisI » Mon Jul 19, 2004 8:10 pm
Best way at all to race in an a/t that I find is to use the brake launch technique, or whatever you may call it.
ICrazyChrisI
Postby krawzyazn » Mon Jul 19, 2004 9:00 pm
ICrazyChrisI wrote:Best way at all to race in an a/t that I find is to use the brake launch technique, or whatever you may call it.
POWER BRAKE lol :drinking:
Postby hari-bhari » Mon Jul 19, 2004 10:48 pm
called a torque launch, and it will sh*t your f*ck right up.
hari-bhari
Postby Mole » Mon Jul 19, 2004 11:12 pm
hari_trivedi wrote: and it will sh*t your f*ck right up.
i dont quite understand that.
did you mean "it will fusk your shizz" right up?
Postby krawzyazn » Mon Jul 19, 2004 11:27 pm
not really if you take care of your tranny like me do the flush every 15k and yes that flush not drain and refil
