SolaraGuy.com • View topic - CEL on aftermarket gauge install
Postby s e y t o n » Sun Jul 18, 2004 10:33 pm
today milt installed my silver gauges. right after the install, he turned the car on and the CEL came on. he reset the battery and it went away. i drove around a lot today after the install (about 2 hours) and it hasnt come back on, i have a feeling that it wont.. just wondering if anybody has had this problem.. if so, what was the code on the CEL?
-Sam
-Sam
Black 2000 5s-fe 5 speed - "Blackie"
s e y t o n
devilish solaraguy
devilish solaraguy
Postby SolaraT » Mon Jul 19, 2004 5:36 am
Yes. Just recently...
http://www.zer0.info/solaraguy/viewtopic.php?t=10054
Did not pull the code yet. It went away before I went to disconect the negative terminal. Was on for two days till it went away.
SolaraT
Solaraguy need mo power guy
Re: CEL on aftermarket gauge install
Postby Mole » Mon Jul 19, 2004 7:38 am
Blackie wrote:today milt installed my silver gauges. right after the install, he turned the car on and the CEL came on. he reset the battery and it went away. i drove around a lot today after the install (about 2 hours) and it hasnt come back on, i have a feeling that it wont.. just wondering if anybody has had this problem.. if so, what was the code on the CEL?
-Sam
did you fill your gas tank up before you went to his house?
Postby s e y t o n » Mon Jul 19, 2004 10:02 am
im curious as to what code itll be, ill check for your update.
yes i did, but it was a good hour and a half drive until i got there..
-Sam
s e y t o n
devilish solaraguy
devilish solaraguy
Postby Mole » Mon Jul 19, 2004 11:17 pm
that might of been your problem.
sometimes, when the gas cap is not on hard enough, it will trigger that stupid CEL.
if your car is running fine, and you feel no problems, then i would have nothing to worry about.
