SolaraGuy.com • View topic - Gas guzzler
Gas guzzler
Gas guzzler
Postby SleeperSolara » Wed Jul 21, 2004 6:04 am
Have a question about my Solara drinkin' up gad like no other. In my 1998 Camry V6 wit a 1MZFE in it, same as the Solara which has a 1MZFE in it. Why does my 2000 Solara drink up more gas than my 98 Camry???
What you guys think the problem could be.
Postby Rudy » Wed Jul 21, 2004 7:03 am
my best guess would be because you drive it harder.
The solara likes to be driven faster than a v6 camry
99 Solara V6 5SPD
Rudy
Postby Jai_Jai_Binks » Wed Jul 21, 2004 8:02 am
what milage do you have on both cars. Were your sparks replaced on the solara with BOSCH. (from what i've heard bosch gives crappy milage). OTher maint stuff done to boht cars will help us to answer this question better. in theory you should get similar milages...for those who think the camry is not as friendly to drive...it may be...but it is much more of a 'perfect sleeper' than the solara!
Edited bosh to bosch...
Last edited by Jai_Jai_Binks on Wed Jul 21, 2004 10:22 am, edited 1 time in total.
Postby Fletch » Wed Jul 21, 2004 10:09 am
19 round town, 25 highway, I don't think that's bad for a S/C'ed V6.
BTW it's Bosch, AKA Robert Bosch Corp.
2006 Legacy GT spec.B
Fletch
Gas Guzzler
Postby SleeperSolara » Thu Jul 22, 2004 5:40 am
I don't drive my car hard that much, and all i have on the V6 Cmary is a TRD radiator cap, which i'm about to switch to the Soalra. the Camry has about 71k on it, and the Solara has about 56-60k on it. Both i think are under mileage. I'm not sure what spark plugs are on the Solara.
Postby TadS » Thu Jul 22, 2004 7:47 am
If I remember right the Camry is slightly lighter than the Solara. That might account for a little bit of the difference.
TadS
Postby Jai_Jai_Binks » Thu Jul 22, 2004 8:14 am
TadS wrote:If I remember right the Camry is slightly lighter than the Solara. That might account for a little bit of the difference.
but then again i think solara was vert marginally more powerful than the camry (to accomodate the difference in weight).
I'm guessing its fuelfilter/sparks and/or some tuneup service that was performed on the camry and is either pending or was done inaccurately on the solara.
