SolaraGuy.com • View topic - help with corner lights please
Postby Peter » Sat Jul 24, 2004 12:33 am
anyone know how to make the lights turn on without the corner lights turning on? i only want the corners to blink when i signal, not when the headlights are on. please
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby thealkimo » Sat Jul 24, 2004 1:22 am
if i remember correctly, solaradude was trying to do this a while back and i believe he succeeded...
thealkimo
Postby krawzyazn » Sat Jul 24, 2004 2:21 am
change the socket to single filiment
Postby Peter » Sat Jul 24, 2004 7:45 am
krawzyazn wrote:change the socket to single filiment
how do i do taht?
Visit Black Sheep
Peter
Postby SolaraT » Sat Jul 24, 2004 8:36 am
1156 bulb
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby whiteflash » Sat Jul 24, 2004 10:09 am
very interesting...
Injen w/CAI Extension
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Postby 1jzgte » Sat Jul 24, 2004 11:33 am
Ok there should be three wires.. Black is the ground. Leave that one intact. There's another 2 wires. I dont know what color they should be but one wire is for constant corner power and the other wire is for the blinker. Err.. here's the fun part. Cut one of those 2 wires and try to figure out which one is lights up the corners. If you happen to cut the wrong one just strip the wires and connect it back together. Unless you have some service manual, that should at least tell which wire is for what purpose.
1jzgte
Postby 1jzgte » Sat Jul 24, 2004 11:35 am
oh and you just cant swap 1157 bulbs for 1156.. you would also have to change the socket which means you have to cut the wire and buy a 1156 socket. Then you have to wire it up.
1jzgte
Postby krawzyazn » Sat Jul 24, 2004 12:41 pm
you would need a new socket
Postby pythonjosh » Sat Jul 24, 2004 12:58 pm
All solaradude did was tape one of the connectors on the bulb. Or you can get a hot wire tester and find out which wire behind the housing is for the running lights, and cut and tape it off.
Josh
pythonjosh
Postby Peter » Sat Jul 24, 2004 6:03 pm
thanks for the help guys
Visit Black Sheep
Peter
Postby Peter » Sat Jul 24, 2004 6:50 pm
its the green and orange wire, or was it blue and orange? i forgot already haha, but i know it was the only wire with orange in case anyone else wants to do this. quick and easy, cut the orange wire and tape it up.
Visit Black Sheep
Peter
Postby krawzyazn » Sat Jul 24, 2004 6:57 pm
get a tester and test the wires
Postby SpikedMantis » Sat Jul 24, 2004 7:43 pm
Wow, this is crazy! I was just thinking about doing this but never read this post until now! I'm going to go try this out!
SpikedMantis
