SolaraGuy.com • View topic - Parking brake light after turning
Postby MalBandito99 » Thu Sep 09, 2004 12:44 pm
Ive been getting this problem for a few weeks now, and Im concerned now since my CEL came on recently, and I reset it. Hasnt come back, but Ive been watching the car very carefully and observing if anything feels wrong. Nothing feels wrong, but the red dashboard BRAKE light comes on when I pull an averagely hard turn, not insane burnout turn or anything, just a turn to merge into traffic from a sideroad, or accelerating thru a left turn light.
Whats goin on here? My brake handle is down, obviously, and I feel no real deceleration or braking going on when the light comes up. Oh yeah, and it goes away after about 8-15 seconds after going straight. Help?
MalBandito99
Postby pythonjosh » Thu Sep 09, 2004 1:11 pm
It means you're getting low on brake fluid. Check it out. As far as the CEL, I dunno. They shouldn't be related.
Josh
pythonjosh
Postby DatSRBoi » Thu Sep 09, 2004 3:57 pm
I've been getting this same problem too lately. For me it happens mostly in the morning when I do allot of turning too onto the highway. My brake fluid is still high. Could it mean a faulty circut? :cry:
Postby xsolara33x » Thu Sep 09, 2004 4:27 pm
i had the same problem... it means you are low on brake fluid... if your brake pads are low the car consumes more brake fluid... you might want to check out your brakes if you haven't done so already... got my brake service and nothing wrong now... good luck...
xsolara33x
Postby DatSRBoi » Thu Sep 09, 2004 4:38 pm
Wow dang. That must be it. I refilled my fluid but I havent replaced my brake pads yet. No wonder solara's are so awesome haha
Postby MalBandito99 » Fri Sep 10, 2004 6:35 am
Damn you guys are good. That has to be whats goin on. Gotta get some new pads on and brake fluid. Ive been feeling like doing this for so long just never crossed my mind til now. Thanks guys.
MalBandito99
Postby xsolara33x » Fri Sep 10, 2004 8:06 am
no problem... thats what all of us are here for... to help eachother out...
xsolara33x
Postby DatSRBoi » Sat Sep 11, 2004 8:26 pm
Oh my goodness..i just got to the brakes today and it wasnt run down at all..it still had over 70 brakeing pad left..and when i checked the fluid it was in kinda the right place...so does that mean i have a fautly brake line? and when i brake it squeaks now..liek bad. i use to brake allot after racing so is that why?
Postby pythonjosh » Sat Sep 11, 2004 9:44 pm
DatSRBoi wrote:Oh my goodness..i just got to the brakes today and it wasnt run down at all..it still had over 70 brakeing pad left..and when i checked the fluid it was in kinda the right place...so does that mean i have a fautly brake line? and when i brake it squeaks now..liek bad. i use to brake allot after racing so is that why?
How do your rotors look? (all 4 of them). If it's not the pads, then it's the rotors, or both. The only thing that would indicate a faulty brake line would be leaking brake fluid. So your master cylinder would be empty, which would turn on your e-brake light when you turn. Make sure there's nothing stuck in your pads and they are aligned right. Aren't brake inspections like really cheap?
pythonjosh
Postby DatSRBoi » Sat Sep 11, 2004 10:19 pm
The rotors are fine and smooth like new. the pads are perfect.. no leaks what so ever and the fluid is still high...the light comes on usually in the morning mostly..and lately here in the morning its cold so could that be it? other then that everything is perfect order other then the light coming on and the brakes continuously squeking when i brake...makes my car annoying on it. or could it be just that the pads are bad?
Postby pythonjosh » Sat Sep 11, 2004 10:46 pm
Well, if everything looks perfect, I'd get a different brand of pads. When it comes time for me change my pads (pretty soon) I'm gonna get slotted rotors, stainless steel brake lines, and new pads (don't know what brand yet).
pythonjosh
Postby DatSRBoi » Sun Sep 12, 2004 6:24 am
Yes I checked the front and back pads. Oh well I just got some new pads. brought me some carbon matalic pads. They claim to give great stopping power at high speeds. paid almost 95 bucks for all four rotors. Lets see if it works and the brake light stays off.
Postby pythonjosh » Sun Sep 12, 2004 12:01 pm
MiltDoggie wrote:Like stated above, sometimes the brakes squeek depending on the brand of the pads.... And have you had the E-brake(rear drum) checked???
V6's have disc brakes all around miltdoggie. Check his sig.
DatSRBoi wrote:Yes I checked the front and back pads. Oh well I just got some new pads. brought me some carbon matalic pads. They claim to give great stopping power at high speeds. paid almost 95 bucks for all four rotors. Lets see if it works and the brake light stays off.
Let us know when you get them on. There are crappy brands of pads.
pythonjosh
