SolaraGuy.com • View topic - Clutch Slipping?
Clutch Slipping?
Clutch Slipping?
Postby Fletch » Thu Sep 09, 2004 7:38 pm
Coming home last night it was about 50 degrees so I got on it pretty good a few times, shifting around 6000RPM. I was watching the tach and after the 1-2 shift and 2-3 shift the gears did not grab right away. Sort of hard to explain but I could also see the tach kind of hovering around before it finally grabbed.
It could be the tires slipping but I don't think they would do that from 2-3 shift. Also, it only does it when the engine is wound up, not from a 3000 or 4000RPM shift.
Car has the original clutch at 115k now. S/C has been on for 15k.
Anybody have any similar situations? Unless it gets bad, I won't replace until next spring with a clutchmasters stage 2.
2006 Legacy GT spec.B
Fletch
Re: Clutch Slipping?
Postby shidosha01 » Thu Sep 09, 2004 8:31 pm
Fletch wrote:Coming home last night it was about 50 degrees so I got on it pretty good a few times, shifting around 6000RPM. I was watching the tach and after the 1-2 shift and 2-3 shift the gears did not grab right away. Sort of hard to explain but I could also see the tach kind of hovering around before it finally grabbed.
Those are signs of a worn clutch especially since its the original one. Upgrade your clutch ASAP. Clutchmasters, TRD ,and SPEC to name a few are very reliable. Good Luck. 8)
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
Postby Rudy » Fri Sep 10, 2004 9:43 am
yeah.
128k and my clutch is slipping like a mother too
99 Solara V6 5SPD
Rudy
Postby TRD_solaRa » Fri Sep 10, 2004 3:48 pm
if you don't feel like spending a whole bunch . . . you could try and "resurface" your flywheel/clutch. It definitely helped out my baby. But, personally I'd get an upgraded clutch first . . . then do that way later on.
TRD_solaRa
