SolaraGuy.com • View topic - Knocking noise front drive front
Postby SleeperSolara » Tue Sep 14, 2004 8:01 am
I just started to notice a knocking noise from the front driver side near the wheel. I think it might be the sway bar mounts being worn out. What you guys think it could be. If it is the sway bar mounts then where can i get some Polyuretharne mounts for the factory sway bar??
Postby sunrise_solara » Tue Sep 14, 2004 10:31 am
When do you hear the noise? When you hit a bump, turn, or just going straight? How many miles on your car, and do you have a reason to suspect the bushings? Urithane are hard to come by but definitely worth it.
sunrise_solara
Knocking noise
Postby SleeperSolara » Tue Sep 14, 2004 1:01 pm
It only happens when i go over certain bumps in the road, or when i go over a pot-hole. My car only has about 55k on it. It might be the bushing, not sure, but i think it has to do with the sway bar.
Postby DavPak » Wed Sep 15, 2004 11:45 am
sounds to me like its a strut mount.
very common on our cars and camry's.
'02 Solara S/C'ed V6 5-spd
DavPak
Postby Mole » Wed Sep 15, 2004 12:02 pm
DavPak wrote:sounds to me like its a strut mount.
i second that.
Knocking noise
Postby SleeperSolara » Wed Sep 15, 2004 6:39 pm
it might be that.
Could take it as a possiblilty.
Postby impactX » Thu Sep 16, 2004 11:31 am
Strut mount
Loose swaybar endlinks
or broken swaybar u-bracket.
impactX
