SolaraGuy.com • View topic - Clutch & Flywheel install
Postby S99Solara » Tue Sep 14, 2004 3:49 pm
flywheel - http://www1.autozone.com/servlet/UiBrok ... 13e7c2.jsp
clutch - http://www1.autozone.com/servlet/UiBrok ... 13f5b1.jsp
guys is this enough information to DIY?
i'm putting in a clutchmaster stage2 + fidanza flywheel
06 4Runner V8 SE
98 1MZ-FE Camry
SOLD! 1999 SE V6 5 Speed,Clutch Masters Stage 2 Clutch Fidanza Lightweight Flywheel, Tein / Tokico, Philips power2night GT150 H4, TWM Shortshifter, Optima Red Top Battery, TRD RSB
S99Solara
Postby PASolara » Tue Sep 14, 2004 6:17 pm
Well thats pretty general i noticed it said u had to remove the engine witch u do not. Actualy If u do it right u dont even have to remove the tranny. I have done my clucth my self 3 times in my drive way. The hardist part will be getting the passenger side axle out. U can just slide the tranny off enough to replace the clucth and flyhweel. Saves alot of work of dropping the sub frame
Good luck let me know if u need any help :drinking:
PASolara
Postby S99Solara » Tue Sep 14, 2004 8:35 pm
yeah come over to my place and give me a hand! =) j/k
do i need any special tools for this job?
06 4Runner V8 SE
98 1MZ-FE Camry
S99Solara
Postby PASolara » Wed Sep 15, 2004 6:09 am
LOL if i lived close i would give ya a hand. No u dont really need any special tools just basic tools and swivel and extentions just remember to clean the clucth and flywheel with brake cleaner when u install it. Oh and use tread Lock on flywheel and bell housing bolts just for safty sake. .
umm thats about it just ask me if u have any qestions.
P.S oh yea just unbolt the slave cylinder not the lines. Saves u from having to bleed the clutch (witch is a little Bitch ) :o
PASolara
Postby S99Solara » Wed Sep 15, 2004 9:09 am
what is the estimate time to get this job done?
when i did my water pump + t-belt it took 6hrs and i was told clutch job will take a lot longer.
btw: where are you located at? i'm in PA
06 4Runner V8 SE
98 1MZ-FE Camry
S99Solara
Postby dan99solara » Wed Sep 15, 2004 1:57 pm
i hate installing clutches im paying to get mine done...
1999 Solara V6 5spd 155k miles
TEIN springs. thats it.
dan99solara
Postby S99Solara » Wed Sep 15, 2004 4:14 pm
expect to pay at least $300+ for the labor
06 4Runner V8 SE
98 1MZ-FE Camry
S99Solara
Postby S99Solara » Thu Sep 16, 2004 8:13 pm
PASolara - can you write me up some shortcut instructions?
06 4Runner V8 SE
98 1MZ-FE Camry
S99Solara
