SolaraGuy.com • View topic - Seat belt bolt.
Seat belt bolt.
Seat belt bolt.
Postby SleeperSolara » Wed Sep 15, 2004 6:42 pm
What should i do if my driver seat belt bolt won't tighten all the way. I think i might have stripped the plate the bolt goes into. What should i do??
Get a bigger bolt, or buy a seat belt bolt holder thingy plate for it. Is the bolt hole welded to the chassis of the car??
Or is the bolt hole a separate metal piece??
I think it is welded on there but not sure.
The bolt stays in place if you don't move in the seat that much.
The bad thing is that my car has no warranty, and it is a daily driver.
Feedback needed badly, and ASAP.
Postby Mole » Wed Sep 15, 2004 6:55 pm
what do you mean not tighten all the way?
can you provide a snap shot of what you are talking about? (how big of gap)
what required you to take it off in the first place?
Seat belt bolt.
Postby SleeperSolara » Wed Sep 15, 2004 7:35 pm
I had to chek on my new Alpine speaker i just put in a few weeks ago, and the speakers were makin weird noises, so you have to take off the seat belt and hanger hook to access the back tray to get to the speakers, you have to do it to both sides to get it off, to access the two clips[one on each side] to take the back tray off to get to the rear speakers.
I found out the rear speakers were hittin on the factory mounts i use, and was puttin the things back in place. Didn't want my car lookin like a junk. Plus i has to do a radiator flush for my car, i was runnin' on water to flush the system. just got it flushed today, and filled up wit Toyota red coolant, and had to change the thermo stat, wit new water inlet o-ring.
Postby Mole » Wed Sep 15, 2004 7:55 pm
uhh... ok... stay on topic.
are you sure you tightend the bolt down as far as you can go? and there is still a gap?
Seat belt bolt
Postby SleeperSolara » Thu Sep 16, 2004 7:22 am
Yeha there is no gap, it will tighten down and get loose, i think the threads on the hole is grinded down from boltin' it down so much. Might get a new bolt alittle bigger than the factory one. Just hope i don't get in a wreck. Since seat belt not bolted in all the way.
Postby indiglosolara » Thu Sep 16, 2004 8:45 am
Try to use thread lock.... that can help...
indiglosolara
Solara 2 xB
Solara 2 xB
Seat belt bolt
Postby SleeperSolara » Thu Sep 16, 2004 9:40 am
Where can i get a thread lock??
That ias that??
Re: Seat belt bolt
Postby indiglosolara » Thu Sep 16, 2004 9:42 am
SleeperSolara wrote:Where can i get a thread lock??
That ias that??
Go to Autozone, They have some there.
when you tighten the bolt dont go all the way. Just tight enough and let the thread lock set. it will keep the bolt from coming out but i would replace it if it becomes worse.
indiglosolara
Solara 2 xB
Solara 2 xB
Seat belt bolt.
Postby SleeperSolara » Fri Sep 17, 2004 11:01 am
I just put in thread lock. Now it tight on ass hell. I don't think it is reversible??
Or is it.
Oh, well.
Re: Seat belt bolt.
Postby indiglosolara » Fri Sep 17, 2004 11:03 am
SleeperSolara wrote:I just put in thread lock. Now it tight on butt hell. I don't think it is reversible??
Or is it.
Oh, well.
it is... but take alot more pressure now. I would use a impact gun to release it next time.
indiglosolara
Solara 2 xB
Solara 2 xB
