SolaraGuy.com • View topic - Oil Change
Oil Change
Oil Change
Postby Whatever » Tue Oct 01, 2002 1:20 am
i jsut got my new solara and i'm wondering when should be my first oil change, some people say i should change oil at the first thousand miles, but some people say i should wait until it gets 5000 miles. Man i'm confused, help...... :o :o :o :o
Whatever
Re: Oil Change
Postby Flipside909 » Tue Oct 01, 2002 7:21 am
Hey wrote:i jsut got my new solara and i'm wondering when should be my first oil change, some people say i should change oil at the first thousand miles, but some people say i should wait until it gets 5000 miles. Man i'm confused, help...... :o :o :o :o
Do it at 3000 miles and you will be fine. Some do it at 1000 miles which is overkill.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Jaimster » Tue Oct 01, 2002 6:02 pm
3000 miles is optimal! I'm kinda late, I'm at 4000 miles. First oil change is due....hmmm will do today! :roll:
Jaimster
Postby ericatdallas » Tue Oct 01, 2002 9:32 pm
Solara1 wrote:3000 miles is optimal! I'm kinda late, I'm at 4000 miles. First oil change is due....hmmm will do today! :roll:
Car abuser!
2000 Solara SLE V6 - Green w/ Beige Interior
ericatdallas
Postby 20SoLaRa02 » Tue Oct 01, 2002 11:04 pm
u guys change oil every 3,000k miles??? i change every 5,000k i have 3,900 and my friend checked it and said it was hella clean!!!
20SoLaRa02
Postby ericatdallas » Tue Oct 01, 2002 11:08 pm
20SoLaRa02 wrote:u guys change oil every 3,000k miles??? i change every 5,000k i have 3,900 and my friend checked it and said it was hella clean!!!
oil is cheaper than metal and is the cheapest insurance to keeping your engine in good shape. But yeah, nowadays it's not necessary to change oil every 3k.
ericatdallas
Postby droomyster » Tue Oct 01, 2002 11:09 pm
ericatdallas wrote:oil is cheaper than metal and is the cheapest insurance to keeping your engine in good shape. But yeah, nowadays it's not necessary to change oil every 3k.
the dealer puts the sticker in my car for every 3k miles... i think it is just so they can get more money or something... i just add 2k onto it and i'm fine. 30k miles in a year = 10 oil changes... that is crazy
droomyster
Postby ericatdallas » Tue Oct 01, 2002 11:11 pm
well if you drive that much you're probably driving a lot of highway and can get away with 6k to 7.5k. But again, for warranty purposes it's best to do with that owner's manual or to be extra precautious, what the dealer says. I think the manual says 5k although the service manual says 3k.
ericatdallas
Postby Flipside909 » Wed Oct 02, 2002 12:32 am
3750 miles if you run in "Severe" conditions as the manual states.
www.clublexus.com
Flipside909
Postby onefiend » Wed Oct 02, 2002 9:25 am
for my first 20 or so oil changes I was getting it done at 3,500 miles...now that I'm using synthetic I'm probabaly gonna go to 5,000 miles before changing... Is this a good idea?
One more question do products like ZMax and Prolong help reduce wear & tear in your engine. I heard and seen on infomercials that they reduce less friction and heat. Is this all BS?
onefiend
Postby Flipside909 » Wed Oct 02, 2002 9:44 am
All those additives are BS. Read this:
http://camryclub.org/articles/aftermarketbs01.htm
www.clublexus.com
Flipside909
Postby ericatdallas » Wed Oct 02, 2002 10:00 am
onefiend wrote:for my first 20 or so oil changes I was getting it done at 3,500 miles...now that I'm using synthetic I'm probabaly gonna go to 5,000 miles before changing... Is this a good idea?
Both the toyota and Lexus (I know they are the same) tell you in the Faq section NOT to extend it even with synthetic.
It's your call, but ALWAYS do what the manufacturer says or exceed it if you don't want to run into any problems in the future. Especially warranty issues.
ericatdallas
Re: Oil Change
Postby Jackass-Jeff » Wed Oct 02, 2002 11:10 am
I think the very first one is at 1000 due to the heavy load of metallic debris (first time the engine actually does real work) then after that, the interval stated is 3000, but people here are saying 4-5k... I changed mine after the first 1000 because I was worried around metallic debris and stuff... but now I'm aimed at around 3000-4000 (depending on the abuse I gave the car)
1GR-FE ftw!
Jackass-Jeff
Re: Oil Change
Postby ericatdallas » Wed Oct 02, 2002 12:36 pm
xravexboix wrote:I think the very first one is at 1000 due to the heavy load of metallic debris (first time the engine actually does real work) then after that, the interval stated is 3000, but people here are saying 4-5k... I changed mine after the first 1000 because I was worried around metallic debris and stuff... but now I'm aimed at around 3000-4000 (depending on the abuse I gave the car)
It might not help but it definitely doesn't hurt it.
ericatdallas
Postby krook » Wed Oct 02, 2002 8:54 pm
btw, anybody change their own oil??? i looked in my owner's manual to see if i'm tuggin' on the right bolt to drain my oil pan, but it doesn't say. i asked about this earlier, but no one replied. anyway, i got it changed by some wannabe Jiffy Lube place, and when they were done, i tried to see if i could remove the bolt that i was trying to get off, but it was still stuck!
the bolt i'm trying to remove is tigher than a 12 year old!Image
ewww j/k
am i messin' with the wrong bolt??
krook
