SolaraGuy.com • View topic - Ratting In Right Rear Of Car
Postby Duffman » Fri Sep 17, 2004 3:31 pm
Hi all, I've got a 2002 Solara, SE V6, 5-Speed... and I've got a rattling sound in the back of my car, on the right. I've taken off the panel in the back seat, checked the trunk thinking it was my jack... I can't find anything that's making a rattling sound. I was thinking (gasp!) that it was my shocks, maybe the tower is loose (hope not!). Any suggestions?
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
Postby sunrise_solara » Fri Sep 17, 2004 6:34 pm
Have you replaced anything suspension-wise, like your struts or sway bar? When does the noise appear (rough pavement or turning)? Could be the strut.
sunrise_solara
Postby Duffman » Sat Sep 18, 2004 6:03 am
It does appear on bumps... and no, I haven't replaced anything in there which is what weirds me out.
Duffman
Postby geminimouse » Sat Sep 18, 2004 6:39 am
could be the rear strut mounts
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby Duffman » Sat Sep 18, 2004 8:21 am
I just pulled the rear deck, took a look around... nothing I can find is loose. I guess my next stop is the Toyota dealer...
Duffman
Postby chinaxb0y » Wed Sep 22, 2004 5:13 pm
did u change ur springs ??? if u did ...check if the top bolts r tighten on the shock tower... cuz i had the same problem and didn't know what it was... it was the bolts on the shock tower...
chinaxb0y
Postby Duffman » Wed Sep 22, 2004 8:01 pm
chinaxb0y wrote:did u change ur springs ??? if u did ...check if the top bolts r tighten on the shock tower... cuz i had the same problem and didn't know what it was... it was the bolts on the shock tower...
Stock springs, stock struts, everything is as Toyota made it.
It's under warranty still so it has a doctor's appointment Monday... BTW, the mechanics were like "Holy sh*t!" when they saw it was a 2002 V6 5-Speed, as were a couple salesmen at the dealership. w00t for 2002 SE V6 Manuals. ;)
Duffman
Postby HTown-Solara » Sun Sep 26, 2004 12:46 pm
so what happened? did they figure out what was making the sound in the back? I have the same rattling noise and its riving me crazy!
HTown-Solara
Postby Jaimster » Sun Sep 26, 2004 2:06 pm
Take the body in the trunk out. ha ha J/K :lol:
Do you have a rear light on the back dash, cuz sometimes that rattles.
Jaimster
Postby Maud'Dib » Mon Sep 27, 2004 12:23 am
Mine just started doing the same thing, only when i go over bumps.
Maud'Dib
suspension
Postby sloara » Tue Sep 28, 2004 5:33 pm
I have that same problem. The noise is coming from my end-links. They should not move at all and if they do, you'll here a rattle.
Scott
sloara
Re: suspension
Postby DatSRBoi » Tue Sep 28, 2004 6:24 pm
sloara wrote:I have that same problem. The noise is coming from my end-links. They should not move at all and if they do, you'll here a rattle.
Scott
So how do you fix that problem becuase i think i have the same issue but not sure?
Re: suspension
Postby Duffman » Thu Sep 30, 2004 1:29 pm
Scott
The Toyota dealer didn't have the struts in stock, so I take it back next Monday. They ordered a new strut tower and the top mount for it, not sure what the exact problem was but will ask. I wasn't allowed "in" with the car when they were working on it, but I was able to be by the entrance, growling because all the Toyota mechanics were standing around drooling at the 5-speed. Whoever has the "Quit humping my car; owner privelage!" siggy is right on the money. :P
Duffman
Postby 2002greenhornet » Tue Nov 01, 2005 5:30 pm
Duffman,
What ever happened with this? I'm having the exact same rattle, but mine's lowered on Tein/Tokico setup.
Thanks
Steve
2002 SLE V6
2002greenhornet
Postby BradOwens » Tue Nov 01, 2005 6:01 pm
my solara does this 2. when i turn off all my music and roll up the windows when i go over bumps it rattles pretty bad. ive pretty much forgot about it. all my tools and jack are in good also
BradOwens
