SolaraGuy.com • View topic - What voltage is your car running under?
Postby 808Camry » Sat Sep 18, 2004 2:57 pm
For those who have a volt meter or an SAFC II, at night when you're at a stop and have your foot on the break or when you roll your windows up or down and just hold it there what does your voltage read? While my foot is on the break after a good warm up it dips to as low as 11.8-12.6 and 13.2 when just driving or in neutral.
Just curious if this is normal and preventable? I have upgraded my ground wires btw if that helps any.
808Camry
Postby Mole » Sat Sep 18, 2004 4:34 pm
thats about right.
it normally flucuates anywhere from 11-14.
Postby Yanks0114 » Sat Sep 18, 2004 6:33 pm
I monitor voltage on my radar detector and on my nav.
Under no load at idle it should be 12+
With A/C blasting and a system on, I've seen it dip as low as 11.2 or 11.3
While the car is running i usually see 13+ with no load and 12.5+ with A/C on.
My voltage goes as high as 14.1
It also all depends on your battery.
The yellow top battery really helped my voltage
Your cars electronics are designed to handle 10.5v-14.4 or so
Postby HKSV6SLE » Sun Sep 19, 2004 5:20 pm
my voltage runs around 14 when i start my car up and then around 11.8 to 12.5 running. if u drop under 11 u mnight start to worry cuz that means ur voltage is a bit too low. :drinking:
2008 LEXUS IS350 SGM
www.lexusnet.com
HKSV6SLE
Postby 5S-FZE » Fri Sep 24, 2004 11:14 pm
Whats up Ron, mine reads 14.2v - 14.4v in the morning when warming up and when im just driving around or at stop light it stays constant at 13.2v lowest i see it drop is when the fans kick it.. itll drop as low as 11.8v but itll jump right back up to 13.2v. Oh and BTW i seen you at circuit city tonight.. i was hanging out with some buddies at the roadshop department.. you going on the toyota\lexus cruise on october 23rd ?
5s-fze
my camry is built and blown, i wanna be built and get blown too !
5S-FZE
