SolaraGuy.com • View topic - New Strut maybe...
New Strut maybe...
New Strut maybe...
Postby whiteflash » Tue Sep 21, 2004 6:52 pm
When i drive and when i got over little bumps its sound like a rattling from my back left i checked to see if the tire was loose so now im assuming its the strut any help on this guys?
Injen w/CAI Extension
Vogtland Springs
Tokico Struts
Custom Full exhaust
TWM Shortshiftter
8000K HID Kit
whiteflash
Re: New Strut maybe...
Postby indiglosolara » Tue Sep 21, 2004 6:54 pm
whiteflash wrote:When i drive and when i got over little bumps its sound like a rattling from my back left i checked to see if the tire was loose so now im assuming its the strut any help on this guys?
if you are lowered on stock struts its probably a blown strut or bad strut mount.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby DatSRBoi » Tue Sep 21, 2004 6:58 pm
So its better to buy the whole deal rather the spring only? I was told it dies faster if you buy the springs only...is that true?
Postby shidosha01 » Tue Sep 21, 2004 7:14 pm
DatSRBoi wrote:So its better to buy the whole deal rather the spring only? I was told it dies faster if you buy the springs only...is that true?
That is true. You blow your stock struts much quicker. Your stock struts were made to handle the factory height of the car. Once you swap out to lowering springs only you then compress the stock struts at an undesirable rate to blow quicker. I strongly recommend the Tokico struts.
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
Postby Mole » Tue Sep 21, 2004 7:16 pm
shidosha01 wrote:I strongly recommend the Tokico struts.
i second that.
Postby DatSRBoi » Tue Sep 21, 2004 7:38 pm
Dang. That be scary if I'm racing a trash talker and BOOMMM. what are the price for those struts then? Theres over 1G huh?
Postby 1jzgte » Tue Sep 21, 2004 8:18 pm
DatSRBoi wrote:Dang. That be scary if I'm racing a trash talker and BOOMMM. what are the price for those struts then? Theres over 1G huh?
what the heck did you just say???
1jzgte
Postby Duffman » Wed Sep 22, 2004 5:08 am
I have been having the same problem, on the right side. It's annoying, and I can't find an easy way to get to the source. So I'm going to the Toyota dealer this afternoon (stock struts, not lowered) and hopefully it'll be under warranty.
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
Struts
Postby SleeperSolara » Wed Sep 22, 2004 7:01 am
I read some where if you get lowering springs, you can adjust the bump stop.
I thought you could modify the stock strut and have a good/"ok" strut.
SuperStreet had TEIN install lowering springs[the green kind], and the guy modified the stock strut to accodamate the lowerin' of the car.
I have it in one of my SuperStreet magazines.
Postby Yanks0114 » Wed Sep 22, 2004 10:13 am
It could be your strut mounts that are shot. Thats the most common complain about the stock suspension.
If you have lowering springs and stock struts, you should only expect 1 year or around 12k miles out of them before their blown. Its better to do it right the first time
Postby Duffman » Wed Sep 22, 2004 1:04 pm
Is finding the mount and replacing it hard to do on your own? What would be required? If someone can get me good information, I'll grab the digital camera and get a tutorial going. 8)
Duffman
Re: Struts
Postby Mole » Wed Sep 22, 2004 2:44 pm
SleeperSolara wrote:I thought you could modify the stock strut and have a good/"ok" strut.
you'd better re-read that article, because there is no such way to mod the stock struts. (it's not worth the pain/trouble.)
as for the bump stop, just cut 2 rings from the stock bump stop and you should be fine.
Postby TheTamago » Fri Sep 24, 2004 4:54 am
I'm about 2pay checks away b4 I buy my TEIN SS C/Os and have a good shop do the installation within under 1 day's worth since I need a car to drive around since I got nobody to cover for me if I need to work on the weekends. Will also be checking my strut mounts when I was told in my post in the aftermarket section about my TEIN SS Questions.
Btw. Lowering Springs + Aftermarket sport struts cost around $700 at best with installation fees from all the posts about the common strut/spring setups. I was almost gonna go do it but coil overs are definately the extra price. Just that I heard the back wheels are a biatch to setup time to time if that was correct?
TheTamago
Postby Fresco Bob » Sat Sep 25, 2004 9:10 pm
^ya cause you gotta take out the back seat. my springs took 2 hours to install i think, maybe less
Fresco Bob
