SolaraGuy.com • View topic - Passenger door never closes and makes rattling noise
Postby toddhata » Wed Sep 29, 2004 11:41 am
my passenger door doesn't close all the way unless you slam it shut, and there's some rattling noise comming from either the window or inside the door when I hit around 40mph and above. I've checked all I could but couldn't figure either problem out.
toddhata
Postby JoKo » Wed Sep 29, 2004 1:27 pm
Have you taken off the whole door panel? You got something f'd up, and its probably the lock mechanism or something
99 SLE Silver Solara AUTO :-(
TRD Muffler, Injen intake, Euro Tails, Tein Springs, Tokico Shocks
JoKo
Postby toddhata » Wed Sep 29, 2004 4:02 pm
wanted to avoid taking the door apart, one thing I found, if the window is open at all, the door closes each time, so the top of the window must be hitting something, but I couldn't see anything wrong, any ideas?
toddhata
Postby JoKo » Wed Sep 29, 2004 4:25 pm
or the bottom is hitting something, wish I could help you but ive dont know
JoKo
Postby Yanks0114 » Wed Sep 29, 2004 5:02 pm
has your car ever been in an accident? Sounds like the hinges aren't lined up right
Postby toddhata » Wed Sep 29, 2004 5:41 pm
no accidents, just started happening one day, a few months ago, very odd.
toddhata
Postby sunrise_solara » Fri Oct 01, 2004 2:55 pm
Sounds like the door is out of alignment, like warped hinges. You haven't been swinging on the door with the window down have you? :wink: Anyway, check the striker plate on the jamb and see if there is unnatural wear on the top (like grooves or finish is worn off). Take it to a bodyshop and see if they can line it back up or put shims in it.
sunrise_solara
