SolaraGuy.com • View topic - clicking noise while braking or sometimes turning
Postby hari-bhari » Mon Oct 04, 2004 8:43 pm
i hear this weird clicking noise usually the first time i drive my car out of the deck. it happens when i brake, usually on a downwards slope, and seems to be coming from the rear, sort of a metallic click of something snapping back into place...any ideas? car drives fine in terms of handling and braking. oh and this is not related to my new wheels/suspension. i heard it before i had the new stuff put on, but ignored it.
hari-bhari
Postby DatSRBoi » Mon Oct 04, 2004 9:24 pm
Interesting. I had the same noise too but from the front more then the back. I was told it was only the sway bar and anti-roll bar doing its job at pulling at you. So my best guess is that its just same with you. Its could just be stiff suspension doing its job. It could also mean its breaking in and getting loose over time.
Postby cdeez » Tue Oct 05, 2004 7:23 am
I guess im not the only one. I get that same clicking right before I brake. It doesn't do it all the time, but if i do a light braking it clicks. I asked the guy at the brake shop and he said its the brakes resettling. I don't really believe it though, cause when I bought the car brand new it wasn't doing that. any ideas as to what it can be folks?
last standing...
Socalara...
cdeez
Postby Stock Solara SEV6 » Tue Oct 05, 2004 12:40 pm
Brake rotors are bare steel. Bare steel will rust very quickly when exposed to any humidity. The area covered by the brake pad does not rust. So, in the morning you end up with a rusted rotor with one area that is not rusted. This then can cause a sound or a slight pedal pulsation until the rust is worn off. More humid, more rust, more noticeable.
Or it could be something else totally.....
2001 V6 5-speed
Stock Solara SEV6
Postby 562solara02 » Tue Oct 05, 2004 12:41 pm
i thought i had a brake prob. or something when i heard it on my ride but i guess its common
Image<--- MY CAR ALARM
562solara02
Clickin' noise
Postby SleeperSolara » Wed Oct 06, 2004 7:01 am
It is the steering parts.
It happens to my dads 98 Camry, it very common in our cars.
When we brought the car to the dealer to get it checked out, they found that one of our shocks were leakin'[ not to freak you guys out].
So we asked another friends and his said it was the steering mechs.
Postby hari-bhari » Wed Oct 06, 2004 9:44 am
so is it a major problem that needs repair?
hari-bhari
Postby krawzyazn » Wed Oct 06, 2004 12:19 pm
check your cv boots also
Postby satchmo » Wed Oct 06, 2004 12:51 pm
I have the exact same problem and it is only noticible when the car is cold or has been sitting a while. I have had my local brake specialist look at it a million times. They think I am crazy. Mine, also, is in the rear.
satchmo
Postby sunrise_solara » Thu Oct 07, 2004 5:10 am
Do those of you who experienced the clicking (in the rear) use the emergency brake when you park your car? It could be that the e-brake is resettling a little slower because of friction on the guide. It could be worth a shot to break the thing down and check it. BTW, this is a guesstimation on my part, so...
sunrise_solara
Postby satchmo » Thu Oct 07, 2004 6:59 am
I rarely us my parking/e-brake.
satchmo
Postby neo6205 » Thu Oct 07, 2004 10:57 pm
I had the exact same problem except could be from a different origin. I painted my calipers and the offset on the rotor. I taped off the actual rotor but I guess I missed a little spot and got some paint on it. I talked to a friend who owns a service shop and he said to take it out on a backroad, go like 60 mph and step on the brake. I did this three times and the sound was gone forever.
Maybe you have a small rust spot as pointed out by SSSEV6 or some foreign object caught stuck between the rotor and pad. I would recomend doing the brake stand option or getting that rotor turned. This will leave it smooth.
I hold no responsibility if you kill yourself by stepping on the brake at 60 mph.
neo6205
Postby esculatus » Fri Oct 08, 2004 11:01 am
krawzyazn wrote:check your cv boots also
Yeah, sounds like CV axel/boot crack
esculatus
