SolaraGuy.com • View topic - How to check engine error codes on a 2000 SE (check engine)
Postby Sirkbac » Mon Oct 04, 2004 9:10 pm
Yesterday I replaced my Cat/flex pipe with an aftermarket "high flow" unit, the OEM flex pipe had rotted apart. After about 150 miles the check engine light came on. Nothing looks amiss with the engine, O2 sensor is hooked up and all fluids are correct. Is there some trick to checking the engine codes, or do I need a scanner of some sort? Car isn't driving any diffrently from before to after the check engine light.
Ed H.
2002 Mazda Protege5
2000 Honda CBR 929rr
1984 Kawasaki 750 Turbo
www.cbr929rr.com
Sirkbac
Postby Yanks0114 » Mon Oct 04, 2004 10:15 pm
OBD I had a trick with LEDs, I believe there is a modified version for OBD II but it isn't accurate.
Goto autozone or a place that can read codes. Also you could buy an obd II scanner, i have the one from scantools.net and i love it
