SolaraGuy.com • View topic - Drag Racing tips?
Drag Racing tips?
Drag Racing tips?
Postby SBCelicaGT » Fri Oct 08, 2004 4:38 pm
So I've never been drag racing before and I'll be goin to Famoso next thursday. I don't want to look like a retard so I wanted to know if you guys had any tips for launching with the 1MZ engine?
I've got a 5spd tranny, 11lb flywheel, and the car weighs about 2700lbs. I believe the suspension is about 14 years old so the weight transfer is going to be horrible. Assuming I do halfway decent, what kind of trap speeds and ETs should I be expecting?
Are you guys just dumping the clutch or is it better to feather the throttle? Whats a good launch RPM for the 1MZ engine?
Thanks for any suggestions.
1990 Toyota Celica 1MZ V6
14.7@95mph @ Famoso
All motor. hehehehehe.
SBCelicaGT
Postby Mole » Fri Oct 08, 2004 5:17 pm
i would of always thought you already upgraded your suspension.
as for launch, i have nothing to say, but lower your tire pressure for better grip.
all that torque, so little weight.
Postby SBCelicaGT » Fri Oct 08, 2004 7:00 pm
Nah. I have too many expenses to upgrade everything at one time. I just finished upgrading the brakes and will upgrade the suspension in the spring.
How low do guys typically lower their tire pressure? Its a pity nobody has a pair of 14" drag slicks I could borrow. I have an extra set of wheels I could put them on.
14.7@95mph @ Famoso
SBCelicaGT
Postby all_red » Fri Oct 08, 2004 7:14 pm
I usually run 20~25 in the fronts, 40 in the rears. I drop the cluch at 2000~2500. Good Luck!
5-speed V6.
TRD Supercharger.
TRD Short Throw Shifter.
Tokico/Eibach combo.
all_red
Postby all_red » Fri Oct 08, 2004 7:15 pm
Ohh yea, don't run with more than 1/4 tank of gas.
5-speed V6.
TRD Supercharger.
all_red
Postby TRD_solaRa » Fri Oct 08, 2004 7:23 pm
i'd say since u got the V6 motor, which will be plenny torque, idle it at about 2500 - 2600ish before you get the yellows . . . jus mess with it around there when you hit the tracks. since your suspension is kinna shytty, you're gonna have some traction problems more than likely. shoootz
TRD_solaRa
Postby 99V6solaraSE » Fri Oct 08, 2004 11:29 pm
not that it really matters but doesnt the solara weigh more than 2700lbs.. ?
99V6solaraSE
Postby all_red » Sat Oct 09, 2004 12:00 am
99V6solaraSE wrote:not that it really matters but doesnt the solara weigh more than 2700lbs.. ?
3200lbs, he's talking about his celica I guess!
5-speed V6.
TRD Supercharger.
all_red
Postby Mole » Sat Oct 09, 2004 1:53 am
^ yes, he has a 1mz motor inside a celica.
Postby TRD MCV20L » Sat Oct 09, 2004 6:34 pm
i wish our solaras weighed 2700 lbs. that celica must fly with the 1mz
TRD MCV20L
Postby SBCelicaGT » Mon Oct 18, 2004 11:43 am
On thursday, at Famoso, during Sport Compact Car's sponsored event, Track Attack, I had a chance to drag race for the first time.
The car did better than expected. Aside from the times I misshifted, I ran solid 14.7XX's all day long in the +90 degree weather with my best trap speed at 95mph. I think if I had improved my launches I could probably get down to a 14.5 with the car. My best 60ft time was 2.232. This was done on street tires(at 20psi), and 14 year old stock suspension. I think with slicks and better suspension(and a better driver!) the car could hit high 13's.
My reaction times weren't too bad for a drag newbie. My best R/T was 0.184 and most were right around 0.2.
I found the best way to get the car to scoot was to feather the clutch around 2500rpm till the car started moving and then dump it. If I wasn't so concerned about clutch wear I think it would be better to start around 3500rpm instead.
I think somebody at the event got a video of my car running. If so, I'll post it here.
14.7@95mph @ Famoso
SBCelicaGT
Postby thakidd » Mon Oct 18, 2004 1:16 pm
good numbers i wanna get sum drag radials for my camry....Oh and nice 60ft looks like mine
"Happieness Is Being Blown"
14.3@96 60ft 2.173
http://media.putfile.com/sc-camry
thakidd
