SolaraGuy.com • View topic - Fuel Filter Location
Postby Coconut » Sun Oct 10, 2004 3:09 pm
Does anyone know what is the location of the fuel filter in '99 Solara V6?
Thanks
Coconut
Postby lazyboyz69 » Sun Oct 10, 2004 3:16 pm
i believe its under the intake box....
lazyboyz69
Postby bronzemaxell » Sun Oct 10, 2004 4:29 pm
lazyboyz69 wrote:i believe its under the intake box....
yeah, i seen it under da intake air box, mounted on the body frame, driver side, and i was told to use a flare wrench as well.
bronzemaxell
Postby SC V6 » Sun Oct 10, 2004 6:38 pm
yeah... its a hard nut to get off... I used a flare nut on the actual metal nut, then a regular open ended wrench and held the fuel filter w\ that... there is a plastic nut on the fuel filter that won't move, but gives a good grip... then took a screw driver and pryed the two apart.. worked really well.. Jim@foreign affairs taught me that trick
SC V6
Postby 19solara99 » Thu May 05, 2005 10:02 am
yea, i basically did the same. i used two flare nut wrenchs to get a good grip, and then used a monkey wrench to squeeze both of the wrenches together...worked really well,,i bearly used any muscle..
19solara99
Postby SpeedSTARs » Sat May 07, 2005 1:09 am
SC V6 wrote:yeah... its a hard nut to get off... I used a flare nut on the actual metal nut, then a regular open ended wrench and held the fuel filter w\ that... there is a plastic nut on the fuel filter that won't move, but gives a good grip... then took a screw driver and pryed the two apart.. worked really well.. Jim@foreign affairs taught me that trick
Yup... The installation is kind of ruff mostly due to the location of that darn :2gunfire: nut (a blind operation). All I can say is Jims Fuel System Upgrade Kit rocks. I'd recommend this to anyone with the forced induction. :D
-G :bcrowd:
SpeedSTARs
