SolaraGuy.com • View topic - Light warning!
Light warning!
Light warning!
Postby greeensolara » Wed Oct 20, 2004 9:37 pm
for some reason the light warning keeps on coming on, i took the bulb out of the middle brake light because my spoiler has a l.e.d light on it. and it looks pretty gay with all four lights. anyway, the warning light on the cluster came on. so i put the bulb back in, and disconnected the battery to restart the ecu. but the light still came on. so i looked at the spoiler light hook up and all wut it is, is an extension from the right brake light. does anyone have an idea if its from the extension. because i know its not from the middle brake light in the windsheild. thnx guys!
P.S. i tried the search botton to see if this problem happened b4, but couldn't find a solution.
greeensolara
Postby pythonjosh » Wed Oct 20, 2004 9:55 pm
First thing, you don't need to reset the ecu for this problem. So you don't have to redo your radio settings. Just check every single one of your exterior lights. I have found that the light indicator only turns on when the blown out light is trying to be used, i.e. if the reverse light is blown, then the indicator light would only turn on when you're in reverse. The car wouldn't know a light is burned out if it isn't trying to light it up. If that windshield brake light works, then a different light is out. Let us know what you find.
Josh
pythonjosh
Postby greeensolara » Wed Oct 20, 2004 10:29 pm
all my lights are working. and this problem happened rite after i got my spoiler installed. so i honestly have no idea wuts goin on. coz once i took the windshield bulb out, it came on, put it back in and it still was on, so i have no idea at this point! :o :o :o :o
greeensolara
Postby Mole » Wed Oct 20, 2004 10:35 pm
have you tried unhooking the spoiler brake light ?
Postby Jon11582 » Wed Oct 20, 2004 10:42 pm
If you install take out any of your factory bulbs, includin the 3rd brake light, the warning light will come on. The only way to get this off is to rewire the aftermarket spoiler to the 3rd brake light (alot more of a pain than to a side brake light) and install some kind of resistor to make the load simulate the regular 3rd brake light bulb. The only OTHER way to get rid of this is to take out the bulb for the rear light failure light.
Have a friend press on the brakes on and off while your parking lights are on and hazards are on to check all your rear bulbs to make sure nothing else blew out in the meanwhile. If the Ebrakes on, you can also throw it in reverse for good measure. That should light up every rear bulb in every state.
2000 Black Solara SE
Jon11582
Postby FLASH » Thu Oct 21, 2004 7:12 am
You have my spoiler so I went through the same thing. The LED in the spoiler doesn't provide enough power to register that it is working, so the car thinks the light is blown out. You need to keep the bulb plugged in on the thrid brake light so that the car registers the correct wattage. Your other option is to just drive around with the warning light on. Just tint your rear window and you'll be fine since you cant see the thrid brake light...that's what i did.
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby greeensolara » Thu Oct 21, 2004 12:14 pm
true that flash, i have my window tinted limo. but u can still see that sucka at nite, and it really looks gay, i think ill just drive around wiht it like that, o well. thnx guys for all this info.
greeensolara
Postby greeensolara » Thu Oct 21, 2004 7:49 pm
yea most likely when i have the time do take out my cluster crap. thnx n e ways
greeensolara
Postby WTF?? » Thu Oct 21, 2004 11:33 pm
why dont you just leave that third brake bulb in... but not let it sit in the holster... just tape it down sumwhere so it duznt shine visibly
hope u know what i mean
Retired... its been fun Image
WTF??
Postby Mole » Thu Oct 21, 2004 11:55 pm
solara nytez wrote:why dont you just leave that third brake bulb in... but not let it sit in the holster... just tape it down sumwhere so it duznt shine visibly
ditto.
Postby greeensolara » Fri Oct 22, 2004 12:19 pm
ditto.
coz i never thought of that, lol. good lookin kenny! :bday: :bday: :bday:
greeensolara
Postby WTF?? » Fri Oct 22, 2004 1:02 pm
greeensolara wrote:coz i never thought of that, lol. good lookin kenny! :bday: :bday: :bday:
^He just called me KENNY!!! :x
haha no offense taken... kenny has a nice blue solara too
WTF??
Postby indiglosolara » Fri Oct 22, 2004 1:23 pm
Hahahaha...... I guess i can be called PHI instead of Kenny..
lolz.. j/k..
indiglosolara
Solara 2 xB
Solara 2 xB
